is there a way to transfer tags from one site to another by a simple copy etc…
Or is there an alternative using commandline or api?
Thanks for a hint.
Ralf
Thanks for a hint.
Ralf
you can copy the tags.mk file from etc/check_mk/conf.d/wato and from etc/check_mk/multisite.d/wato to the new site directories.
Karl
You can use web api for that for more info: https://checkmk.de/cms_web_api_references.html#Hosttagbefehle
if you have more than the default tags on new site you have to merge them with the output of the step 1, if not you can just copy and paste
