I’ve installed check-mk-enterprise-2.1.0p17.x86_64 on Oracle Enterprise Linux 8. When I try to create a new site I get the traceback show below. I am currently using checkmk for other sites using OEL7. Is there any hope to fix this or will I have to downgrade?
Thanks for any input.
[root@dubuqqcmk01p ~]# omd create jack 15:43:56 [20/1808]
Adding /opt/omd/sites/jack/tmp to /etc/fstab. Creating temporary filesystem /omd/sites/jack/tmp...OK Updating core configuration... Generating configuration for core (type cmc)... WARNING: The number of configured checkers is higher than the number of available CPUs. To avoid unnecessary context switches, the number of checkers should be limited to the number of CPUs. Recommended number of checkers: 2 Starting full compilation for all hosts Creating global helper config...OK Creating cmc protobuf configuration...OK Executing post-create script "01_create-sample-config.py"... -| Traceback (most recent call last): -| File "/omd/sites/jack/lib/omd/scripts/post-create/01_create-sample-config.py", line 15, in <module> -| from cmk.gui import main_modules, watolib -| File "/omd/sites/jack/lib/python3/cmk/gui/main_modules.py", line 20, in <module> -| import cmk.gui.plugins.main_modules # noqa: F401 # pylint: disable=no-name-in-module,unused-import -| File "/omd/sites/jack/lib/python3/cmk/gui/plugins/main_modules/__init__.py", line 9, in <module> -| load_plugins(__file__, __package__) -| File "/omd/sites/jack/lib/python3/cmk/utils/plugin_loader.py", line 123, in load_plugins -| importlib.import_module("%s.%s" % (package_name, plugin_name)) -| File "/omd/sites/jack/lib/python3.9/importlib/__init__.py", line 127, in import_module -| return _bootstrap._gcd_import(name[level:], package, level)
-| File "/omd/sites/jack/lib/python3/cmk/gui/plugins/main_modules/cre.py", line 10, in <module>
-| import cmk.gui.bi
-| File "/omd/sites/jack/lib/python3/cmk/gui/bi.py", line 27, in <module>
-| import cmk.gui.watolib as watolib
-| File "/omd/sites/jack/lib/python3/cmk/gui/watolib/__init__.py", line 59, in <module>
-| import cmk.gui.userdb as userdb
-| File "/omd/sites/jack/lib/python3/cmk/gui/userdb.py", line 41, in <module>
-| from cmk.gui.plugins.userdb.ldap_connector import MKLDAPException
-| File "/omd/sites/jack/lib/python3/cmk/gui/plugins/userdb/ldap_connector.py", line 46, in <module>
-| import ldap # type: ignore[import]
-| File "/omd/sites/jack/lib/python3.9/site-packages/ldap/__init__.py", line 34, in <module>
-| import _ldap
-| ImportError: /lib64/libk5crypto.so.3: undefined symbol: EVP_KDF_ctrl, version OPENSSL_1_1_1b
ERROR (exit code: 1)
Restarting Apache...OK
Created new site jack with version 2.1.0p17.cee.
The site can be started with omd start jack.
The default web UI is available at http://dubuqqcmk01p/jack/
# cat /etc/os-release
NAME="Oracle Linux Server"
VERSION="8.6"
ID="ol"
ID_LIKE="fedora"
VARIANT="Server"
VARIANT_ID="server"
VERSION_ID="8.6"
PLATFORM_ID="platform:el8"
PRETTY_NAME="Oracle Linux Server 8.6"
ANSI_COLOR="0;31"
CPE_NAME="cpe:/o:oracle:linux:8:6:server"
HOME_URL="https://linux.oracle.com/"
BUG_REPORT_URL="https://bugzilla.oracle.com/"
ORACLE_BUGZILLA_PRODUCT="Oracle Linux 8"
ORACLE_BUGZILLA_PRODUCT_VERSION=8.6
ORACLE_SUPPORT_PRODUCT="Oracle Linux"
ORACLE_SUPPORT_PRODUCT_VERSION=8.6
