Could you help me to know how I can activate the “criticality” option located in Custom attributes in the configuration of a server.
In this option we can choose “Do not monitor thid host” and this helps make the server invisible to Check_mk without having to delete it.
In the Check_mk that I currently use I see the option but after saving the changes it does not apply them, the server still appears visible and I send notifications.
I attach an image where the mentioned option is.
Check_mk version: 2.0.0p4
Thanks for answering.
Look in the rules section and I did not find anything, I did not know in which option I could create it, could you guide me, please?
