Allo
So when it comes to hosts, theres that little pane that can be opened to reschedule checks, check paramaters etc…
I was wondering if anyone had come across custom commands for the little pane.
Essentially we’re monitoring some ILOs and dracs via SNMP and I’d love to be able to launch a console window using check_mk.
Any thoughts/ideas appreciated
r.sander
(Robert Sander)
July 31, 2020, 2:30pm
2
That’s called “Custom Icons & Actions”.
The URLs are configured in the global settings and assigned via rulesets.
https://checkmk.com/cms_views.html#Adding%20your%20own%20icons%20and%20actions
But keep in mind that modern browsers forbid to open external applications from inside a web-page for security reasons.
cjcox
(Christopher Cox)
August 1, 2020, 2:28am
4
I recently did a video about Netdata integration, but it does cover how you add icons and actions for both host status gui icons as well as host and/or service menu items.
definately worth a watch, and thank you to all the amazing replies, given me a lot to think about
system
(system)
Closed
September 1, 2020, 5:25pm
6
