is there a possibility to change the svcproblems view for all users?
We have some Checks that are annoying, but can’t be in a downtime.
I would like to exclude them from the tactical overview.
I tried to clone the view with the omdadmin User and set the filter, but it won’t change the default view.
Be sure to check the option “Make this view available for other users”. If this option is set, and the view is saved under the same ID than the orignial, the customized view has precedence over the builtin view.
