I am trying to figure out why CheckMK is not iterating through the OID’s and just stops after its initial oid query. If I just do a snmpwalk on the command line and the base ID that works fine and is shown below as well. It starts with .1.3.6.1.4.1.994.3.4.7.20.1.3.0 which doesn’t exist but then should start iterating and go to .1.3.6.1.4.1.994.3.4.7.20.1.3.1 and then .1.3.6.1.4.1.994.3.4.7.20.1.3.2 and so on but it just stops.
Below is the Plugin.
#!/usr/bin/env python3
#from cmk.utils import debug
from pprint import pprint
def discover_webmon(section):
pprint(section)
for input_desc, input_configured, input_live_desc, input_live_level in section:
if input_configured == "1" and input_desc:
yield Service(item=input_desc)
def check_webmon(item, section):
if input_desc == item:
if input_live_level == "Normal":
s = State.OK
elif input_live_level == "Status":
s = State.OK
elif input_live_level == "Critical":
s = State.CRIT
elif input_live_level == "Major":
s = State.WARN
elif input_live_level == "Warning":
s = State.WARN
elif input_live_level == "Minor":
s = State.WARN
yield Result(state = s, summary = input_live_desc)
return
register.snmp_section(
name = "webmon_slot3",
detect = any_of(
equals(".1.3.6.1.4.1.994.3.4.7.17.1.68.3.0", "1"),
equals(".1.3.6.1.4.1.994.3.4.7.17.1.68.3", "1"),
fetch = SNMPTree(
base = '.1.3.6.1.4.1.994.3.4.7.20.1',
oids = [
'3', # Input Description
'10', # Input Configured 0 / 1
'64', # Input Live Description
'65', # Input Live Level
register.check_plugin(
service_name = "%s",
discovery_function = discover_webmon,
check_function = check_webmon,
Below is the debug output from attempting to run the plugin against a unit
OMD[cvt]:~/local/lib/check_mk/base/plugins/agent_based$ cmk --debug --detect-plugins=webmon_slot3 -vvII 835-VALD-WebMon
Discovering services and host labels on: 835-VALD-WebMon
835-VALD-WebMon:
+ FETCHING DATA
[cpu_tracking] Start [7fdfb1e7b100]
[SNMPFetcher] Fetch with cache settings: SNMPFileCache(835-VALD-WebMon, base_path=/omd/sites/cvt/tmp/check_mk/data_source_cache/snmp, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Mode Mode.FORCE_SECTIONS)
webmon_slot3: Fetching data (SNMP walk cache cleared)
Executing BULKWALK of ".1.3.6.1.4.1.994.3.4.7.20.1.3" on 835-VALD-WebMon
.1.3.6.1.4.1.994.3.4.7.20.1.3.0 => [b'NOSUCHINSTANCE'] 'NOSUCHINSTANCE'
Executing BULKWALK of ".1.3.6.1.4.1.994.3.4.7.20.1.10" on 835-VALD-WebMon
.1.3.6.1.4.1.994.3.4.7.20.1.10.0 => [b'NOSUCHINSTANCE'] 'NOSUCHINSTANCE'
Executing BULKWALK of ".1.3.6.1.4.1.994.3.4.7.20.1.64" on 835-VALD-WebMon
.1.3.6.1.4.1.994.3.4.7.20.1.64.0 => [b'NOSUCHINSTANCE'] 'NOSUCHINSTANCE'
Executing BULKWALK of ".1.3.6.1.4.1.994.3.4.7.20.1.65" on 835-VALD-WebMon
.1.3.6.1.4.1.994.3.4.7.20.1.65.0 => [b'NOSUCHINSTANCE'] 'NOSUCHINSTANCE'
[cpu_tracking] Stop [7fdfb1e7b100 - Snapshot(process=posix.times_result(user=0.010000000000000009, system=0.010000000000000009, children_user=0.0, children_system=0.0, elapsed=0.10999999940395355))]
[cpu_tracking] Start [7fdfb1e7bfd0]
[PiggybackFetcher] Fetch with cache settings: NoCache(835-VALD-WebMon, base_path=/omd/sites/cvt/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=True, use_outdated=False, simulation=False)
No piggyback files for '835-VALD-WebMon'. Skip processing.
No piggyback files for '192.168.xxx.xxx'. Skip processing.
[cpu_tracking] Stop [7fdfb1e7bfd0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
No persisted sections
-> Add sections: ['webmon_slot3']
-> Add sections: []
Received no piggyback data
+ ANALYSE DISCOVERED HOST LABELS
Trying host label discovery with: webmon_slot3
SUCCESS - Found no host labels
+ ANALYSE DISCOVERED SERVICES
+ EXECUTING DISCOVERY PLUGINS (1)
Trying discovery with: webmon_slot3
[['NOSUCHINSTANCE', 'NOSUCHINSTANCE', 'NOSUCHINSTANCE', 'NOSUCHINSTANCE']]
SUCCESS - Found no services
If I just do an SNMP walk of the base OID it pulls up just fine but for some reason checkMK isn’t iterating through it…
OMD[cvt]:~/local/lib/check_mk/base/plugins/agent_based$ snmpbulkwalk -v2c -c public 192.168.xxx.xxx .1.3.6.1.4.1.994.3.4.7.20.1
iso.3.6.1.4.1.994.3.4.7.20.1.3.1 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.3.2 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.3.3 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.3.4 = STRING: "AFC SYS 1 CRITICAL"
iso.3.6.1.4.1.994.3.4.7.20.1.3.5 = STRING: "AFC SYS 2 MAJOR"
iso.3.6.1.4.1.994.3.4.7.20.1.3.6 = STRING: "AFC SYS 5 CRITICAL"
iso.3.6.1.4.1.994.3.4.7.20.1.3.7 = STRING: "TURIN SONET CRITICAL"
iso.3.6.1.4.1.994.3.4.7.20.1.3.8 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.3.9 = STRING: "835.VALD.F9500 MINOR"
iso.3.6.1.4.1.994.3.4.7.20.1.3.10 = STRING: "835.VALD.F9500 MAJOR"
iso.3.6.1.4.1.994.3.4.7.20.1.3.11 = STRING: "835.VALD.F9500 CRITICAL"
iso.3.6.1.4.1.994.3.4.7.20.1.3.12 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.3.13 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.3.14 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.3.15 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.3.16 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.4.1 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.4.2 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.4.3 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.4.4 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.4.5 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.4.6 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.4.7 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.4.8 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.4.9 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.4.10 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.4.11 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.4.12 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.4.13 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.4.14 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.4.15 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.4.16 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.5.1 = STRING: "On"
iso.3.6.1.4.1.994.3.4.7.20.1.5.2 = STRING: "On"
iso.3.6.1.4.1.994.3.4.7.20.1.5.3 = STRING: "On"
iso.3.6.1.4.1.994.3.4.7.20.1.5.4 = STRING: "On"
iso.3.6.1.4.1.994.3.4.7.20.1.5.5 = STRING: "On"
iso.3.6.1.4.1.994.3.4.7.20.1.5.6 = STRING: "On"
iso.3.6.1.4.1.994.3.4.7.20.1.5.7 = STRING: "On"
iso.3.6.1.4.1.994.3.4.7.20.1.5.8 = STRING: "On"
iso.3.6.1.4.1.994.3.4.7.20.1.5.9 = STRING: "On"
iso.3.6.1.4.1.994.3.4.7.20.1.5.10 = STRING: "On"
iso.3.6.1.4.1.994.3.4.7.20.1.5.11 = STRING: "On"
iso.3.6.1.4.1.994.3.4.7.20.1.5.12 = STRING: "On"
iso.3.6.1.4.1.994.3.4.7.20.1.5.13 = STRING: "On"
iso.3.6.1.4.1.994.3.4.7.20.1.5.14 = STRING: "On"
iso.3.6.1.4.1.994.3.4.7.20.1.5.15 = STRING: "On"
iso.3.6.1.4.1.994.3.4.7.20.1.5.16 = STRING: "On"
iso.3.6.1.4.1.994.3.4.7.20.1.10.1 = INTEGER: 1
iso.3.6.1.4.1.994.3.4.7.20.1.10.2 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.10.3 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.10.4 = INTEGER: 1
iso.3.6.1.4.1.994.3.4.7.20.1.10.5 = INTEGER: 1
iso.3.6.1.4.1.994.3.4.7.20.1.10.6 = INTEGER: 1
iso.3.6.1.4.1.994.3.4.7.20.1.10.7 = INTEGER: 1
iso.3.6.1.4.1.994.3.4.7.20.1.10.8 = INTEGER: 1
iso.3.6.1.4.1.994.3.4.7.20.1.10.9 = INTEGER: 1
iso.3.6.1.4.1.994.3.4.7.20.1.10.10 = INTEGER: 1
iso.3.6.1.4.1.994.3.4.7.20.1.10.11 = INTEGER: 1
iso.3.6.1.4.1.994.3.4.7.20.1.10.12 = INTEGER: 1
iso.3.6.1.4.1.994.3.4.7.20.1.10.13 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.10.14 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.10.15 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.10.16 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.11.1 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.11.2 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.11.3 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.11.4 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.11.5 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.11.6 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.11.7 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.11.8 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.11.9 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.11.10 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.11.11 = INTEGER: 1
iso.3.6.1.4.1.994.3.4.7.20.1.11.12 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.11.13 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.11.14 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.11.15 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.11.16 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.12.1 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.12.2 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.12.3 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.12.4 = INTEGER: 1
iso.3.6.1.4.1.994.3.4.7.20.1.12.5 = INTEGER: 1
iso.3.6.1.4.1.994.3.4.7.20.1.12.6 = INTEGER: 1
iso.3.6.1.4.1.994.3.4.7.20.1.12.7 = INTEGER: 1
iso.3.6.1.4.1.994.3.4.7.20.1.12.8 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.12.9 = INTEGER: 1
iso.3.6.1.4.1.994.3.4.7.20.1.12.10 = INTEGER: 1
iso.3.6.1.4.1.994.3.4.7.20.1.12.11 = INTEGER: 1
iso.3.6.1.4.1.994.3.4.7.20.1.12.12 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.12.13 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.12.14 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.12.15 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.12.16 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.17.1 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.17.2 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.17.3 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.17.4 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.17.5 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.17.6 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.17.7 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.17.8 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.17.9 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.17.10 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.17.11 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.17.12 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.17.13 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.17.14 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.17.15 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.17.16 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.18.1 = INTEGER: 2
iso.3.6.1.4.1.994.3.4.7.20.1.18.2 = INTEGER: 2
iso.3.6.1.4.1.994.3.4.7.20.1.18.3 = INTEGER: 2
iso.3.6.1.4.1.994.3.4.7.20.1.18.4 = INTEGER: 1
iso.3.6.1.4.1.994.3.4.7.20.1.18.5 = INTEGER: 2
iso.3.6.1.4.1.994.3.4.7.20.1.18.6 = INTEGER: 1
iso.3.6.1.4.1.994.3.4.7.20.1.18.7 = INTEGER: 1
iso.3.6.1.4.1.994.3.4.7.20.1.18.8 = INTEGER: 1
iso.3.6.1.4.1.994.3.4.7.20.1.18.9 = INTEGER: 3
iso.3.6.1.4.1.994.3.4.7.20.1.18.10 = INTEGER: 2
iso.3.6.1.4.1.994.3.4.7.20.1.18.11 = INTEGER: 1
iso.3.6.1.4.1.994.3.4.7.20.1.18.12 = INTEGER: 2
iso.3.6.1.4.1.994.3.4.7.20.1.18.13 = INTEGER: 1
iso.3.6.1.4.1.994.3.4.7.20.1.18.14 = INTEGER: 3
iso.3.6.1.4.1.994.3.4.7.20.1.18.15 = INTEGER: 2
iso.3.6.1.4.1.994.3.4.7.20.1.18.16 = INTEGER: 1
iso.3.6.1.4.1.994.3.4.7.20.1.44.1 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.44.2 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.44.3 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.44.4 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.44.5 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.44.6 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.44.7 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.44.8 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.44.9 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.44.10 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.44.11 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.44.12 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.44.13 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.44.14 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.44.15 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.44.16 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.64.1 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.64.2 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.64.3 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.64.4 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.64.5 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.64.6 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.64.7 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.64.8 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.64.9 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.64.10 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.64.11 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.64.12 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.64.13 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.64.14 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.64.15 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.64.16 = STRING: "Off"
iso.3.6.1.4.1.994.3.4.7.20.1.65.1 = STRING: "Normal"
iso.3.6.1.4.1.994.3.4.7.20.1.65.2 = STRING: "Normal"
iso.3.6.1.4.1.994.3.4.7.20.1.65.3 = STRING: "Normal"
iso.3.6.1.4.1.994.3.4.7.20.1.65.4 = STRING: "Normal"
iso.3.6.1.4.1.994.3.4.7.20.1.65.5 = STRING: "Normal"
iso.3.6.1.4.1.994.3.4.7.20.1.65.6 = STRING: "Normal"
iso.3.6.1.4.1.994.3.4.7.20.1.65.7 = STRING: "Normal"
iso.3.6.1.4.1.994.3.4.7.20.1.65.8 = STRING: "Normal"
iso.3.6.1.4.1.994.3.4.7.20.1.65.9 = STRING: "Normal"
iso.3.6.1.4.1.994.3.4.7.20.1.65.10 = STRING: "Normal"
iso.3.6.1.4.1.994.3.4.7.20.1.65.11 = STRING: "Normal"
iso.3.6.1.4.1.994.3.4.7.20.1.65.12 = STRING: "Normal"
iso.3.6.1.4.1.994.3.4.7.20.1.65.13 = STRING: "Normal"
iso.3.6.1.4.1.994.3.4.7.20.1.65.14 = STRING: "Normal"
iso.3.6.1.4.1.994.3.4.7.20.1.65.15 = STRING: "Normal"
iso.3.6.1.4.1.994.3.4.7.20.1.65.16 = STRING: "Normal"
iso.3.6.1.4.1.994.3.4.7.20.1.67.1 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.67.2 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.67.3 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.67.4 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.67.5 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.67.6 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.67.7 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.67.8 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.67.9 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.67.10 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.67.11 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.67.12 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.67.13 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.67.14 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.67.15 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.67.16 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.75.1 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.75.2 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.75.3 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.75.4 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.75.5 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.75.6 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.75.7 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.75.8 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.75.9 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.75.10 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.75.11 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.75.12 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.75.13 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.75.14 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.75.15 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.75.16 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.116.1 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.116.2 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.116.3 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.116.4 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.116.5 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.116.6 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.116.7 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.116.8 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.116.9 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.116.10 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.116.11 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.116.12 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.116.13 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.116.14 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.116.15 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.116.16 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.117.1 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.117.2 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.117.3 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.117.4 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.117.5 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.117.6 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.117.7 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.117.8 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.117.9 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.117.10 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.117.11 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.117.12 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.117.13 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.117.14 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.117.15 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.117.16 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.118.1 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.118.2 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.118.3 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.118.4 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.118.5 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.118.6 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.118.7 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.118.8 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.118.9 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.118.10 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.118.11 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.118.12 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.118.13 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.118.14 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.118.15 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.118.16 = ""
iso.3.6.1.4.1.994.3.4.7.20.1.119.1 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.119.2 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.119.3 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.119.4 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.119.5 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.119.6 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.119.7 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.119.8 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.119.9 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.119.10 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.119.11 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.119.12 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.119.13 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.119.14 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.119.15 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.119.16 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.120.1 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.120.2 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.120.3 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.120.4 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.120.5 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.120.6 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.120.7 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.120.8 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.120.9 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.120.10 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.120.11 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.120.12 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.120.13 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.120.14 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.120.15 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.120.16 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.121.1 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.121.2 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.121.3 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.121.4 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.121.5 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.121.6 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.121.7 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.121.8 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.121.9 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.121.10 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.121.11 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.121.12 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.121.13 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.121.14 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.121.15 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.121.16 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.122.1 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.122.2 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.122.3 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.122.4 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.122.5 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.122.6 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.122.7 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.122.8 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.122.9 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.122.10 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.122.11 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.122.12 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.122.13 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.122.14 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.122.15 = INTEGER: 0
iso.3.6.1.4.1.994.3.4.7.20.1.122.16 = INTEGER: 0
