Dell idrac 10 snmp problem
CMK version:
Checkmk Pro 2.5.0p10
OS version:
Oracle Linux 8.9
Check idrac via the SNMP
Disk Solid State Disk 0:1:0 [Disk 0 in Backplane 1 of RAID Controller in SL 5] Size: 480 GB, Disk state: unknown(!), Component state: OK
Disk Solid State Disk 0:1:1 [Disk 1 in Backplane 1 of RAID Controller in SL 5] Size: 480 GB, Disk state: unknown(!), Component state: OK
Disk Solid State Disk 0:1:2 [Disk 2 in Backplane 1 of RAID Controller in SL 5] Size: 480 GB, Disk state: unknown(!), Component state: OK, global hotspare
Raid Controller 1 Status of CPU.1 (PCI Slot 0): other
Raid Controller 2 Status of PERC H965i Front (Embedded): other
Raid Controller 3 Status of PERC H965i Front (Embedded): other
But from idrac everything looks ok.
idrac 10, dell r770
Device Type: 17G Monolithic
Firmware Version: 1.30.30.55
That’s how it has been showing ever since the server was first connected to Checkmk.
What happens if you use the Redfish integration instead of SNMP?
I haven’t used this before. I assume you mean:
SetupAgents > Other integrations > Redfish Compatible Management Controller > Add rule: Redfish Compatible Management Controller
I have a few less services running via Redfish, but there are no errors, and the most important ones are there.
Thanks for fast help
