We have been using the plugin of TomTretbar to monitor our Dell PowerScale. Thanks @ttr .
https://exchange.checkmk.com/p/powerscale
However when we wanted to upgrade to CheckMK v2.4 we get this message:
-| 05/08 Agent based plugins...
-| Obsolete file: '/omd/sites/site01/local/lib/check_mk/base/plugins/agent_based/powerscale_quotas.py'
-| Obsolete file: '/omd/sites/site01/local/lib/check_mk/base/plugins/agent_based/powerscale_system.py'
-| Obsolete file: '/omd/sites/site01/local/lib/check_mk/base/plugins/agent_based/powerscale_nodes.py'
-| Obsolete file: '/omd/sites/site01/local/lib/check_mk/base/plugins/agent_based/powerscale_events.py'
-| Obsolete file: '/omd/sites/site01/local/lib/check_mk/base/plugins/agent_based/powerscale_synciq.py'
-| The file(s) residing in `local/lib/check_mk/plugins/agent_based` will no longer be loaded in Checkmk 2.4.
-| See: https://checkmk.com/werk/17201
-| The above file(s) are part of the extension package powerscale 2.1.4.
This kind of blocks your upgrade path to 2.4.
any ideas to get this plugin working for 2.4?
Thanks
François
