Hi. Shortly: How do I disable the active check “Check_MK HW/SW Inventory” for hosts that I only have an IMPI management board interface and no agent?
CMK version: 2.1.0b7
OS version: Check_MK in Docker on Rocky Linux kernel 4.18.0-348.el8.0.2.x86_64
I see the following
The hosts have an “IMPI address only”. Configuration is as follows:
Summary
OMD[cubi]:~$ cmk --debug -vvn bld-2-25-10
Checkmk version 2.1.0b7
Trying to acquire lock on /omd/sites/cubi/var/check_mk/license_usage/next_run
Got lock on /omd/sites/cubi/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/cubi/var/check_mk/license_usage/history.json
Got lock on /omd/sites/cubi/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/cubi/var/check_mk/license_usage/history.json
Released lock on /omd/sites/cubi/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/cubi/var/check_mk/license_usage/next_run
Released lock on /omd/sites/cubi/var/check_mk/license_usage/next_run
- FETCHING DATA
Source: SourceType.MANAGEMENT/FetcherType.IPMI
[cpu_tracking] Start [7fd3a9852640]
[IPMIFetcher] Fetch with cache settings: DefaultAgentFileCache(bld-2-25-10, base_path=/omd/sites/cubi/tmp/check_mk/data_source_cache/mgmt_ipmi, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Too old. Age is 27 sec, allowed is 0 sec)
[IPMIFetcher] Execute data source
Connecting to 172.16.65.120:623 (User: root, Privlevel: 2)
Fetching sensor data via UDP from 172.16.65.120:623
Fetching inventory information via UDP from 172.16.65.120:623
Raw reading states of SD2: [‘Unknown state 0 for reading type 111/sensor type 201’]
Fetching firmware information via UDP from 172.16.65.120:623
Write data to cache file /omd/sites/cubi/tmp/check_mk/data_source_cache/mgmt_ipmi/bld-2-25-10
Trying to acquire lock on /omd/sites/cubi/tmp/check_mk/data_source_cache/mgmt_ipmi/bld-2-25-10
Got lock on /omd/sites/cubi/tmp/check_mk/data_source_cache/mgmt_ipmi/bld-2-25-10
Releasing lock on /omd/sites/cubi/tmp/check_mk/data_source_cache/mgmt_ipmi/bld-2-25-10
Released lock on /omd/sites/cubi/tmp/check_mk/data_source_cache/mgmt_ipmi/bld-2-25-10
Closing connection to 172.16.65.120:623
[cpu_tracking] Stop [7fd3a9852640 - Snapshot(process=posix.times_result(user=0.1299999999999999, system=0.020000000000000018, children_user=0.0, children_system=0.0, elapsed=1.2199999997392297))]
[cpu_tracking] Start [7fd3a4f4cf70]
[PiggybackFetcher] Fetch with cache settings: NoCache(bld-2-25-10, base_path=/omd/sites/cubi/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=True, use_outdated=False, simulation=False)
No piggyback files for ‘bld-2-25-10’. Skip processing.
No piggyback files for ‘172.16.65.120’. Skip processing.
[cpu_tracking] Stop [7fd3a4f4cf70 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))] - PARSE FETCHER RESULTS
<<<ipmi_sensors:sep(124)>>> / Transition NOOPParser → HostSectionParser
<<<ipmi_firmware:sep(124)>>> / Transition HostSectionParser → HostSectionParser
No persisted sections
→ Add sections: [‘ipmi_firmware’, ‘ipmi_sensors’]
→ Add sections: []
Received no piggyback data
[cpu_tracking] Start [7fd3a4f4cd90]
value store: synchronizing
Trying to acquire lock on /omd/sites/cubi/tmp/check_mk/counters/bld-2-25-10
Got lock on /omd/sites/cubi/tmp/check_mk/counters/bld-2-25-10
Releasing lock on /omd/sites/cubi/tmp/check_mk/counters/bld-2-25-10
Released lock on /omd/sites/cubi/tmp/check_mk/counters/bld-2-25-10
Management Interface: IPMI Sensor A Status: OK
Management Interface: IPMI Sensor B Status: OK
Management Interface: IPMI Sensor CMOS_Battery Status: OK
Management Interface: IPMI Sensor Current Status: OK, 0.40 A
Management Interface: IPMI Sensor Dedicated_NIC Status: OK
Management Interface: IPMI Sensor Drive0 Status: OK
Management Interface: IPMI Sensor Drive1 Status: OK
Management Interface: IPMI Sensor M23_VTT_PG Status: OK
Management Interface: IPMI Sensor PCH_Heatsink_Pre Status: OK
Management Interface: IPMI Sensor PG Status: OK
Management Interface: IPMI Sensor Presence Status: OK
Management Interface: IPMI Sensor Pwr_Consumption Status: OK, 88.00 W
Management Interface: IPMI Sensor ROMB_Battery Status: OK
Management Interface: IPMI Sensor Redundancy Status: OK
Management Interface: IPMI Sensor Status Status: OK
Management Interface: IPMI Sensor VCORE_PG Status: OK
Management Interface: IPMI Sensor VSA_PG Status: OK - EXECUTING INVENTORY PLUGINS
aruba_wlc_aps: skipped (no data)
check_mk: skipped (no data)
checkmk_agent_plugins: skipped (no data)
docker_node_info: skipped (no data)
fritz: skipped (no data)
hp_proliant_da_phydrv: skipped (no data)
hp_proliant_mem: skipped (no data)
ibm_mq_channels: skipped (no data)
ibm_mq_managers: skipped (no data)
ibm_mq_queues: skipped (no data)
ipmi_firmware: skipped (no data)
ipmi_firmware: ok
inv_cisco_vlans: skipped (no data)
inv_esx_vsphere_hostsystem: skipped (no data)
inv_if: skipped (no data)
aix_packages: skipped (no data)
aix_service_packs: skipped (no data)
inventory_checkmk: skipped (no data)
checkpoint_vpn_tunnels: skipped (no data)
dmidecode: skipped (no data)
docker_container_labels: skipped (no data)
docker_container_network: skipped (no data)
docker_node_images: skipped (no data)
docker_node_network: skipped (no data)
inventory_esx_vsphere_clusters: skipped (no data)
inventory_esx_vsphere_virtual_machines: skipped (no data)
fortiauthenticator_system: skipped (no data)
fortigate_ha: skipped (no data)
fortimail_system: skipped (no data)
fortisandbox_software: skipped (no data)
fortisandbox_system: skipped (no data)
k8s_assigned_pods: skipped (no data)
k8s_daemon_pod_containers: skipped (no data)
k8s_endpoint_info: skipped (no data)
k8s_ingress_infos: skipped (no data)
k8s_job_container: skipped (no data)
kube_cluster: skipped (no data)
kube_daemonset: skipped (no data)
kube_deployment: skipped (no data)
kube_namespace: skipped (no data)
kube_node: skipped (no data)
kube_pod: skipped (no data)
kube_statefulset: skipped (no data)
lnx_block_devices: skipped (no data)
lnx_ip_r: skipped (no data)
lnx_packages: skipped (no data)
lnx_sysctl: skipped (no data)
lnx_video: skipped (no data)
mssql_clusters: skipped (no data)
oracle_systemparameter: skipped (no data)
snmp_extended_info: skipped (no data)
solaris_addresses: skipped (no data)
solaris_pkginfo: skipped (no data)
solaris_psrinfo: skipped (no data)
solaris_cpus: skipped (no data)
solaris_prtpicl: skipped (no data)
solaris_routes: skipped (no data)
statgrab_net: skipped (no data)
win_disks: skipped (no data)
win_exefiles: skipped (no data)
win_ip_r: skipped (no data)
win_networkadapter: skipped (no data)
win_reg_uninstall: skipped (no data)
win_video: skipped (no data)
win_wmi_software: skipped (no data)
win_wmi_updates: skipped (no data)
juniper_info: skipped (no data)
k8s_nodes: skipped (no data)
k8s_pod_container: skipped (no data)
k8s_roles: skipped (no data)
lnx_if: skipped (no data)
mem_used: skipped (no data)
mssql_instance: skipped (no data)
netapp_api_disk: skipped (no data)
oracle_dataguard_stats: skipped (no data)
oracle_instance: skipped (no data)
oracle_performance: skipped (no data)
oracle_recovery_area: skipped (no data)
oracle_tablespaces: skipped (no data)
perle_chassis_slots: skipped (no data)
perle_psmu: skipped (no data)
snmp_info: skipped (no data)
winperf_if: skipped (no data)
aix_baselevel: skipped (no data)
aix_lparstat_inventory: skipped (no data)
allnet_ip_sensoric: skipped (no data)
citrix_controller: skipped (no data)
citrix_state: skipped (no data)
couchbase_nodes_ports: skipped (no data)
dell_hw_info: skipped (no data)
docker_container_node_name: skipped (no data)
esx_systeminfo: skipped (no data)
fireeye_sys_status: skipped (no data)
hp_proliant_systeminfo: skipped (no data)
infoblox_osinfo: skipped (no data)
infoblox_systeminfo: skipped (no data)
k8s_pod_info: skipped (no data)
k8s_selector: skipped (no data)
k8s_service_info: skipped (no data)
lnx_cpuinfo: skipped (no data)
lnx_distro: skipped (no data)
lnx_uname: skipped (no data)
lparstat_aix: skipped (no data)
netapp_api_info: skipped (no data)
perle_chassis: skipped (no data)
prtconf: skipped (no data)
snmp_os: skipped (no data)
snmp_quantum_storage_info: skipped (no data)
solaris_prtdiag: skipped (no data)
solaris_uname: skipped (no data)
suseconnect: skipped (no data)
win_bios: skipped (no data)
win_computersystem: skipped (no data)
win_cpuinfo: skipped (no data)
win_os: skipped (no data)
win_system: skipped (no data)
[cpu_tracking] Stop [7fd3a4f4cd90 - Snapshot(process=posix.times_result(user=0.07000000000000028, system=0.010000000000000009, children_user=0.0, children_system=0.0, elapsed=0.08999999985098839))]
[mgmt_ipmi] Success, execution time 0.1 sec | execution_time=0.090 user_time=0.070 system_time=0.010 children_user_time=0.000 children_system_time=0.000
