Hi I was trying to monitor docker containers using check mk plugin mk_docker.py.
What i did is i placed mk_docker.py in /usr/lib/check_mk_agent/plugins/ directory.
and then use command —> python /usr/lib/check_mk_agent/plugins/mk_docker.py
I have also installed python docker library using pip install docker
I have also reloaded xinetd agent,is there is something which i am missing cuz i simply see no output in my checkmk,might i have to create a new host or something?
My checkmk agent version/os is:
<<<check_mk>>>
Version: 1.6.0p8
AgentOS: linux
