**CMK version: checkmk/check-mk-raw:2.1.0-latest
**OS version: running on Docker version 20.10.17, build 100c701 on MAC M2 2022
docker run -p8082:5000 --rm checkmk/check-mk-raw:2.0.0p6
Starting nagios…ERROR
also you closed the following ticket w/o solution… and I was evaluating Checkmk for its support…
Hibl there,
You could go through that manual: Debugging of the cmc - Checkmk Knowledge Base - Checkmk Knowledge Base
To be honest, this is tested and build for the cmc, but tools like strace should help you to narrow that down.
Br
Anastasios
