When editing a dynamic configuration connection in 1.6.0p11 I face the following options:
the last two of which have the same description. I checked the corresponding WATO plugin (~/lib/python/cmk/gui/cee/plugins/wato/dcd.py
) and found this corresponding code snippet:
"max_cache_age",
Transform(Age(
title=
_("Keep hosts while piggyback source sends piggyback data only for other hosts for" ),
default_value=3600,
forth=lambda p: 3600 if p == "global" else p),
("validity_period",
Age(title=_(
default_value=60)),
Maybe someone can tell me the correct titles for the two options. I reckon the first one should indicate how long a dynamically created host is kept if no more piggyback data for it arrives (default=1hr) but what about the second one? Unfortunately the manual doesn’t help either because it shows a completely different screenshot for these settings.
Thank you in advance
Dirk
