“Dieses” Hosts…
Der Endpoint http://localhost:5000/mwscan_site/check_mk/api/1.0/domain-types/host_config/collections/all zeigt alle Hosts und mit jq
ist das ein JSON mit 18056 Zeilen
Ich habe mal ein wenig gegraben, vielleicht hilft das:
"title": "Server was about to send an invalid response.",
"status": 500,
"detail": "This is an error of the implementation.",
"ext": {
"errors": {
"snmp_v3_credentials": [
"Unknown field."
"orig": {
"id": "host",
"domainType": "host_config",
"value": [
"id": "s11",
"title": "s1x",
"links": [
"rel": "self",
"href": "http://checkmk.iznet/example_site/check_mk/api/1.0/objects/host_config/s11",
"method": "GET",
"type": "application/json",
"domainType": "link"
"rel": "urn:org.restfulobjects:rels/update",
"method": "PUT",
"rel": "urn:org.restfulobjects:rels/delete",
"method": "DELETE",
"rel": "urn:com.checkmk:rels/folder_config",
"href": "http://checkmk.iznet/example_site/check_mk/api/1.0/objects/folder_config/~switches",
"method": "GET",
"domainType": "link",
"title": "The folder config of the host."
"rel": "urn:com.checkmk:rels/download",
"href": "http://checkmk.iznet/example_site/check_mk/api/1.0/domain-types/agent/actions/download/invoke?os_type=aix_tgz&host_name=s11",
"method": "GET",
"title": "Download the aix_tgz agent of the host."
"href": "http://checkmk.iznet/example_site/check_mk/api/1.0/domain-types/agent/actions/download/invoke?os_type=linux_deb&host_name=s11",
"method": "GET",
"title": "Download the linux_deb agent of the host."
"href": "http://checkmk.iznet/example_site/check_mk/api/1.0/domain-types/agent/actions/download/invoke?os_type=linux_rpm&host_name=s11",
"method": "GET",
"title": "Download the linux_rpm agent of the host."
"href": "http://checkmk.iznet/example_site/check_mk/api/1.0/domain-types/agent/actions/download/invoke?os_type=linux_tgz&host_name=s11",
"method": "GET",
"title": "Download the linux_tgz agent of the host."
"href": "http://checkmk.iznet/example_site/check_mk/api/1.0/domain-types/agent/actions/download/invoke?os_type=solaris_pkg&host_name=s11",
"method": "GET",
"title": "Download the solaris_pkg agent of the host."
"href": "http://checkmk.iznet/example_site/check_mk/api/1.0/domain-types/agent/actions/download/invoke?os_type=solaris_tgz&host_name=s11",
"method": "GET",
"title": "Download the solaris_tgz agent of the host."
"href": "http://checkmk.iznet/example_site/check_mk/api/1.0/domain-types/agent/actions/download/invoke?os_type=windows_msi&host_name=s11",
"method": "GET",
"title": "Download the windows_msi agent of the host."
"members": {},
"extensions": {
"folder": "switches/",
"attributes": {
"tag_agent": "no-agent",
"snmp_community": [
"authPriv",
"sha",
"switchname",
"insertpwhere",
"DES",
"insertpwhere"
"tag_snmp_ds": "snmp-v2",
"meta_data": {
"created_at": 1636533532.6656003,
"created_by": "lars",
"updated_at": 1653549312.2342417
"authPriv",
"sha",
"switchname",
"insertpwhere",
"DES",
"insertpwhere"
"ipaddress": "10.20.30.40"
"effective_attributes": null,
"is_cluster": false,
"is_offline": false,
"cluster_nodes": null
Mag die API das Array in der Form nicht?
