Hi All!
I try to use the Check_MK Discovery but this is the output from “Output of check plugin” using the last product version:
CRIT - no unmonitored services found, no vanished services found, no new host labels, [agent] Empty output from agent at TCP port 6556
Starting job…
- FETCHING DATA
[agent] Execute data source
[agent] ERROR: Empty output from agent at TCP port 6556
This is my tests on check_mk environment:
root@checkmk:/tmp# check_mk_agent | less
<<<check_mk>>>
Version: 1.5.0p4
AgentOS: linux
Hostname: checkmk
AgentDirectory: /etc/check_mk
DataDirectory: /var/lib/check_mk_agent
SpoolDirectory: /var/lib/check_mk_agent/spool
PluginsDirectory: /usr/lib/check_mk_agent/plugins
LocalDirectory: /usr/lib/check_mk_agent/local
<<<df>>>
udev devtmpfs 1996416 0 1996416 0% /dev
tmpfs tmpfs 401536 10588 390948 3% /run
/dev/sda1 ext3 4061888 1837032 2224856 46% /ro
root@checkmk:/tmp# telnet 172.16.11.208 6556
Trying 172.16.11.208...
Connected to 172.16.11.208.
Escape character is '^]'.
Connection closed by foreign host.
root@checkmk:/tmp# netstat -putan | grep 6556
tcp 0 0 0.0.0.0:6556 0.0.0.0:* LISTEN 1056/xinetd
What’s the exactly problem? Why can’t connect to the port?
Thanks!
