I have been using my own Python script for many years to query the live status.
Since Werk #7017 the live status is encrypted, I would like to implement this in my script now.
But I can’t get it to work :-/
With the following command I can query the live status with SSL/TLS.
echo -e "GET status\nOutputFormat: json\n\n" | openssl s_client -connect x.x.x.x:6558 -ign_eof -quiet
As an example script let’s take the script from section 2.2 https://checkmk.de/cms_livestatus.html
Does anyone have an idea how I have to adapt the script to query the live status with ssl/tls?
#!/usr/bin/env python
# Sample program for accessing Livestatus from Python
import json, os, socket, ssl
# for local site only: file path to socket
#address = "%s/tmp/run/live" % os.getenv("OMD_ROOT")
# for local/remote sites: TCP address/port for Livestatus socket
#address = ("localhost", 6557)
address = ('x.x.x.x', 6558)
# connect to Livestatus
family = socket.AF_INET if type(address) == tuple else socket.AF_UNIX
sock = socket.socket(family, socket.SOCK_STREAM)
#sock_ssl = ssl.wrap_socket(sock, ssl_version=ssl.PROTOCOL_TLSv1_2, keyfile=None, certfile=None, server_side=False, cert_reqs=ssl.CERT_NONE)
#sock_ssl = ssl.wrap_socket(sock)
#ssl._create_default_https_context = ssl._create_unverified_context
context = ssl.create_default_context()
#context = ssl.SSLContext(ssl.PROTOCOL_TLS_CLIENT)
context.check_hostname = False
context.verify_mode = ssl.CERT_NONE
#context.load_default_certs()
sock_ssl = context.wrap_socket(sock)
sock_ssl.connect(address)
print sock_ssl.getpeercert()
# send our request and let Livestatus know we're done
sock_ssl.sendall("GET status\nOutputFormat: json\n\n")
sock_ssl.shutdown(socket.SHUT_WR)
# receive the reply as a JSON string
chunks = []
while len(chunks) == 0 or chunks[-1] != "":
chunks.append(sock_ssl.recv(4096))
print(chunks)
sock_ssl.close()
reply = "".join(chunks)
# print the parsed reply
print(json.loads(reply))
