Hey,
I just started with a clean install of cmk, somehow when I try to add my first host, I get this Error:
Error running automation call try-inventory (exit code -9)
What did I do in detail?
I followed the official Tutorial video (Episode 1: Checkmk installieren und Ihre ersten Hosts überwachen). Everything went fine.
In the Agent Bakery I noticed the first message, with progress info as follows:
Agent baking started...
2020-05-22 18:20:47,880 [40] [cmk.web.automations 3980] Error running 'check_mk --automation bake-agents --' (exit code -9)
2020-05-22 18:20:47,881 [40] [cmk.web.background_process 3980] Exception in background function
File "/omd/sites/monitor/lib/python/cmk/gui/background_job.py", line 205, in _execute_function
func_ptr(*args, **kwargs)
File "/omd/sites/monitor/lib/python/cmk/gui/cee/plugins/wato/agent_bakery.py", line 5220, in bake_agents_background_job
watolib.check_mk_local_automation('bake-agents')
File "/omd/sites/monitor/lib/python/cmk/gui/watolib/automations.py", line 126, in check_mk_local_automation
err=errdata)
MKGeneralException: Error running automation call bake-agents (exit code -9)
I ignored it in the first place, but when I then tried to add the localhost as first Host like the tutorial explained, the Error-message quoted above appeared, without finishing the progress as it should.
So far, I nowhere could find information about the exit code -9
. I hope you can help what could cause this behaviour and how to solve this issue.
Regards,
unixor
CMK-Version: 1.6.0p12
System: CentOS 7 (+ firewalld)
