CMK version: Raw 2.1.0p11
OS version: RHEL 7
Started at: 16:09:06. Finished at: 16:09:11.
Error running automation call restart (exit code 1), error:
Nagios Core 3.5.1
Copyright (c) 2009-2011 Nagios Core Development Team and Community Contributors
Copyright (c) 1999-2009 Ethan Galstad
Last Modified: 08-30-2013
License: GPL
Website: http://www.nagios.org
Reading configuration data…
Read main config file okay…
Processing object config directory ‘/omd/sites/srv/etc/nagios/conf.d’…
Processing object config file ‘/omd/sites/srv/etc/nagios/conf.d/templates.cfg’…
Processing object config file ‘/omd/sites/srv/etc/nagios/conf.d/check_mk_templates.cfg’…
Processing object config file ‘/omd/sites/srv/etc/nagios/conf.d/check_mk_objects.cfg’…
Read object config files okay…
Running pre-flight check on configuration data…
Checking services…
Checked 6348 services.
Checking hosts…
Checked 117 hosts.
Checking host groups…
Checked 22 host groups.
Checking service groups…
Checked 9 service groups.
Checking contacts…
Checked 11 contacts.
Checking contact groups…
Checked 34 contact groups.
Checking service escalations…
Checked 0 service escalations.
Checking service dependencies…
Checked 116 service dependencies.
Checking host escalations…
Checked 0 host escalations.
Checking host dependencies…
Checked 0 host dependencies.
Checking commands…
Checked 93 commands.
Checking time periods…
Checked 1 time periods.
Checking for circular paths between hosts…
Checking for circular host and service dependencies…
Checking global event handlers…
Checking obsessive compulsive processor commands…
Checking misc settings…
Total Warnings: 0
Total Errors: 1
***> One or more problems was encountered while running the pre-flight check…
Check your configuration file(s) to ensure that they contain valid
directives and data defintions. If you are upgrading from a previous
version of Nagios, you should be aware that some variables/definitions
may have been removed or modified in this version. Make sure to read
the HTML documentation regarding the config files, as well as the
'Whats New' section to find out what has changed.
An error occurred: Error creating configuration: Configuration for monitoring core is invalid. Rolling back. The broken file has been copied to “/omd/sites/srv/tmp/check_mk/check_mk_objects.cfg.broken” for analysis.
