I want to execute a script if a host goes into down state.
I know there is a event console that do this kind of stuff.
But I don’t see how I can detect via Event-Console if a host is down.
I am using check_mk raw edition.
I also found a tutorial for check_mk using nagios event handler but I am uncertain how to apply this for my problem.
I do not understand what you mean to onest.
I don’t want to collect information with this script, I want to fix a problem that occurs from time to time and only check mk notice it.
Ok,
the idea is not to delete for example all logfiles using a scripted restart etc. that may help you to analyse why for a system crashed.
Sometime hints are shown on the screen of a frozen system.
Ralf
You can use notifications to trigger a script. I use RHEL so the path is: /opt/omd/sites/<sitename>/local/share/check_mk/notifications
Any script in the dir can be addressed via a notification. The second line of the script needs to be the name of the script that shows.
#!/bin/bash
# <name here>
That shows up in the “WATO → Notifications → Rule” Notification method (dropdown)
And in that rule you can pass variables from a check, to the script, like “NOTIFY_HOSTNAME”
Then you can use that to kick off a host restart, service restart, or a multitude of other stuff like generate a ticket via another system.
