Is there a possibility to export a dashboard in CheckMK so it can be imported into a different instance?
So let’s say I create 2 different instances of CheckMK, I create a bunch of dashboard views on one and I can easily move them over to the other one? Or do I have to recreate the same dashboards for every instance?
This feature is currently WIP. We are late in our Checkmk 2.2.0 development cycle, so there is a risk of making the cut. But otherwise it is in the next release
This will not, unless the plugin does something magically work with lastest 2.1 release as both user dashboards and views are stored in memory database (Redis) and you need to manually delete the redis temp files to get your copied dashboards and views.
Checkmk should support this OOB - Id recommend to create a feature request if not already done
