I am running thruk 2.42.2 on CentOS Linux release 8.3.2011. The details are as below.
#rpm -qa | grep thruk
thruk-plugin-reporting-2.42.2-10942.1.x86_64
libthruk-2.40-0.x86_64
thruk-2.42.2-10942.1.x86_64
thruk-base-2.42.2-10942.1.x86_64
#/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 4.4.6
Copyright (c) 2009-present Nagios Core Development Team and Community Contributors
Copyright (c) 1999-2009 Ethan Galstad
Last Modified: 2020-04-28
License: GPLWebsite: https://www.nagios.org
Reading configuration data…
Read main config file okay…
Read object config files okay…Running pre-flight check on configuration data…
Checking objects…
Checked 8 services.
Checked 1 hosts.
Checked 1 host groups.
Checked 0 service groups.
Checked 1 contacts.
Checked 1 contact groups.
Checked 24 commands.
Checked 5 time periods.
Checked 0 host escalations.
Checked 0 service escalations.
Checking for circular paths…
Checked 1 hosts
Checked 0 service dependencies
Checked 0 host dependencies
Checked 5 timeperiods
Checking global event handlers…
Checking obsessive compulsive processor commands…
Checking misc settings…Total Warnings: 0
Total Errors: 0Things look okay - No serious problems were detected during the pre-flight check
I have enabled broker_module in /usr/local/nagios/etc/nagios.cfg. while restarting nagios service I am encountering the Error: Failed to load module. Details are as below.
broker_module=/opt/omd/versions/2.0.0p4.cfe/lib/mk-livestatus/livestatus.o /var/tmp/live.sock
# systemctl status nagios
● nagios.service - Nagios Core 4.4.6
Loaded: loaded (/usr/lib/systemd/system/nagios.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Tue 2021-05-18 19:06:26 UTC; 6s ago
Docs: https://www.nagios.org/documentation
Process: 199308 ExecStopPost=/bin/rm -f /usr/local/nagios/var/rw/nagios.cmd (code=exited, status=0/SUCCESS)
Process: 199300 ExecStart=/usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg (code=exited, status=0/SUCCESS)
Process: 199298 ExecStartPre=/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg (code=exited, status=0/SUCCESS)
Main PID: 199302 (code=exited, status=1/FAILURE)
May 18 19:06:24 nagios nagios[199302]: wproc: Successfully registered manager as @wproc with query handler
May 18 19:06:24 nagios nagios[199302]: wproc: Registry request: name=Core Worker 199306;pid=199306
May 18 19:06:24 nagios nagios[199302]: wproc: Registry request: name=Core Worker 199303;pid=199303
May 18 19:06:24 nagios nagios[199302]: wproc: Registry request: name=Core Worker 199304;pid=199304
May 18 19:06:24 nagios nagios[199302]: wproc: Registry request: name=Core Worker 199305;pid=199305
May 18 19:06:24 nagios nagios[199302]: Error: Could not load module '/opt/omd/versions/2.0.0p4.cfe/lib/mk-livestatus/livestatus.o' -> /opt/omd/versions/2.0.0p4.cfe/lib/mk-livestatus/livestatus.o: cannot >
May 18 19:06:24 nagios nagios[199302]: Error: Failed to load module '/opt/omd/versions/2.0.0p4.cfe/lib/mk-livestatus/livestatus.o'.
May 18 19:06:24 nagios nagios[199302]: Error: Module loading failed. Aborting.
May 18 19:06:24 nagios systemd[1]: nagios.service: Main process exited, code=exited, status=1/FAILURE
May 18 19:06:26 nagios systemd[1]: nagios.service: Failed with result 'exit-code'.
Please guide. Thanks in Advance.
Best Regards,
Kaushal
