I have installed checkmk enterprise trail. Will the features be available after the trial period?
Features under the Add tab in the main dashboard?
What version of Checkmk are you running?
OMD - Open Monitoring Distribution Version 2.4.0.cce ( enterprise edition )
the CCE is not the Enterprise Edition, but the Cloud Edition.
The CCE has a free tier of up to 750 services on one site. As long as you stick to that, all features will continue to be available.
If you exceed 750 services or use distributed monitoring, you will need to apply a license. Otherwise, you will no longer be able to activate changes.
Hope that helps
