I’m trying to monitor a Commvault Hyperscale-X appliance wich is based on RHEL. All is good, but I’m unable to add mounted filesystems like /hedvig/d… they are just not displayed after discovery. This is some kind of software defined storage solution, but in the end all those d* disks are mounted xfs filesystems.
The funny thing is that the df module does not show them, but the mount module does. So I’m able to check the mount options but not the size. Other fs are discovered as expected.
Example:
/dev/mapper/hedvigmetavg-hedvigd2 300G 95G 205G 32% /hedvig/d2
/dev/sdf 17T 16T 843G 95% /hedvig/d6
/dev/sdn 17T 16T 891G 95% /hedvig/d14
/dev/sds 17T 16T 914G 95% /hedvig/d19
/dev/sdj 17T 16T 838G 96% /hedvig/d10
/dev/sdi 17T 16T 844G 95% /hedvig/d9
/dev/sdd 17T 16T 885G 95% /hedvig/d4
/dev/sdh 17T 16T 859G 95% /hedvig/d8
/dev/sdy 17T 16T 946G 95% /hedvig/d25
/dev/sdt 17T 16T 910G 95% /hedvig/d20
/dev/sdw 17T 16T 914G 95% /hedvig/d23
/dev/sdz 17T 16T 983G 95% /hedvig/d26
/dev/sdaa 17T 16T 872G 95% /hedvig/d3
/dev/sdx 17T 16T 1017G 94% /hedvig/d24
/dev/sdu 17T 16T 970G 95% /hedvig/d21
/dev/sdq 17T 16T 994G 95% /hedvig/d17
/dev/sdm 17T 16T 933G 95% /hedvig/d13
/dev/sdk 17T 16T 1.1T 94% /hedvig/d11
/dev/sdv 17T 16T 948G 95% /hedvig/d22
/dev/sdp 17T 16T 968G 95% /hedvig/d16
/dev/sdo 17T 16T 987G 95% /hedvig/d15
/dev/sdl 17T 16T 1.1T 94% /hedvig/d12
/dev/sdr 17T 16T 1.1T 94% /hedvig/d18
/dev/sde 17T 16T 839G 96% /hedvig/d5
/dev/sdg 17T 16T 838G 96% /hedvig/d7
Environment:
**CMK version:** 2.1.0p1
**OS version:** Server Debian 11.4, Clients unknown RHEL version
**Error message:** none
**Output of “cmk --debug -vvn hostname”:** (If it is a problem with checks or plugins)
Checkmk version 2.1.0p1
Trying to acquire lock on /omd/sites/backup_team/var/check_mk/license_usage/next_run
Got lock on /omd/sites/backup_team/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/backup_team/var/check_mk/license_usage/history.json
Got lock on /omd/sites/backup_team/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/backup_team/var/check_mk/license_usage/history.json
Released lock on /omd/sites/backup_team/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/backup_team/var/check_mk/license_usage/next_run
Released lock on /omd/sites/backup_team/var/check_mk/license_usage/next_run
+ FETCHING DATA
[cpu_tracking] Start [7f56f0489040]
[TCPFetcher] Fetch with cache settings: DefaultAgentFileCache(sdes1601-dp.xxx.xxx, base_path=/omd/sites/backup_team/tmp/check_mk/cache, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Too old. Age is 46 sec, allowed is 0 sec)
Connecting via TCP to 10.24.56.221:6556 (5.0s timeout)
Reading data from agent
Write data to cache file /omd/sites/backup_team/tmp/check_mk/cache/sdes1601-dp.xxx.xxx
Trying to acquire lock on /omd/sites/backup_team/tmp/check_mk/cache/sdes1601-dp.xxx.xxx
Got lock on /omd/sites/backup_team/tmp/check_mk/cache/sdes1601-dp.xxx.xxx
Releasing lock on /omd/sites/backup_team/tmp/check_mk/cache/sdes1601-dp.xxx.xxx
Released lock on /omd/sites/backup_team/tmp/check_mk/cache/sdes1601-dp.xxx.xxx
Closing TCP connection to 10.24.56.221:6556
[cpu_tracking] Stop [7f56f0489040 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=2.2200000025331974))]
[cpu_tracking] Start [7f56f0489430]
[PiggybackFetcher] Fetch with cache settings: NoCache(sdes1601-dp.xxx.xxx, base_path=/omd/sites/backup_team/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=True, use_outdated=False, simulation=False)
No piggyback files for 'sdes1601-dp.xxx.xxx'. Skip processing.
No piggyback files for '10.24.56.221'. Skip processing.
[cpu_tracking] Stop [7f56f0489430 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
<<<df>>> / Transition HostSectionParser -> HostSectionParser
<<<lnx_bonding:sep(58)>>> / Transition HostSectionParser -> HostSectionParser
<<<ovs_bonding:sep(58)>>> / Transition HostSectionParser -> HostSectionParser
<<<multipath>>> / Transition HostSectionParser -> HostSectionParser
<<<postfix_mailq>>> / Transition HostSectionParser -> HostSectionParser
<<<postfix_mailq_status:sep(58)>>> / Transition HostSectionParser -> HostSectionParser
<<<chrony:cached(1668015688,30)>>> / Transition HostSectionParser -> HostSectionParser
<<<ipmi:cached(1668015697,300):sep(124)>>> / Transition HostSectionParser -> HostSectionParser
<<<ipmi_discrete:cached(1668015690,300):sep(124)>>> / Transition HostSectionParser -> HostSectionParser
<<<logwatch>>> / Transition HostSectionParser -> HostSectionParser
No persisted sections
-> Add sections: ['check_mk', 'checkmk_agent_plugins_lnx', 'chrony', 'cifsmounts', 'cmk_agent_ctl_status', 'cpu', 'df', 'diskstat', 'ipmi', 'ipmi_discrete', 'job', 'kernel', 'labels', 'lnx_bonding', 'lnx_if', 'local', 'logwatch', 'md', 'mem', 'mounts', 'multipath', 'nfsmounts', 'ovs_bonding', 'postfix_mailq', 'postfix_mailq_status', 'ps_lnx', 'systemd_units', 'tcp_conn_stats', 'uptime', 'vbox_guest']
-> Add sections: []
Received no piggyback data
[cpu_tracking] Start [7f56f03cb610]
value store: synchronizing
Trying to acquire lock on /omd/sites/backup_team/tmp/check_mk/counters/sdes1601-dp.xxx.xxx
Got lock on /omd/sites/backup_team/tmp/check_mk/counters/sdes1601-dp.xxx.xxx
Releasing lock on /omd/sites/backup_team/tmp/check_mk/counters/sdes1601-dp.xxx.xxx
Released lock on /omd/sites/backup_team/tmp/check_mk/counters/sdes1601-dp.xxx.xxx
Bonding Interface bond1 Status: up, Mode: IEEE 802.3ad Dynamic link aggregation, enpsf3/88:E9:A4:5E:C4:44 up, enpsf5/88:E9:A4:5E:E4:44 up
Bonding Interface bond2 Status: up, Mode: IEEE 802.3ad Dynamic link aggregation, enpsf4/88:E9:A4:5E:C4:45 up, enpsf6/88:E9:A4:5E:E4:45 up
CPU load 15 min load: 69.60, 15 min load per core: 1.09 (64 cores)
CPU utilization Total CPU: 45.23%
Check_MK Agent Version: 2.1.0p1, OS: linux, Agent plugins: 2, Local checks: 0
Disk IO SUMMARY Read: 501 MB/s, Write: 101 MB/s, Latency: 6 milliseconds
Filesystem / 15.47% used (20.65 of 133.51 GB), trend: +478.92 kB / 24 hours
Filesystem /boot 15.78% used (149.35 of 946.73 MB), trend: 0.00 B / 24 hours
Filesystem /boot/efi 0.38% used (3.62 of 951.12 MB), trend: 0.00 B / 24 hours
Filesystem /flache/metadatadir 0.11% used (32.97 MB of 29.79 GB), trend: 0.00 B / 24 hours
Filesystem /hedvig/d2 30.2% used (90.56 of 299.85 GB), trend: +23.31 GB / 24 hours
Filesystem /hedvig/hpod/data 0.15% used (45.54 MB of 29.79 GB), trend: +1.15 MB / 24 hours
Filesystem /hedvig/hpod/log 0.28% used (85.58 MB of 29.79 GB), trend: +14.21 MB / 24 hours
Filesystem /mnt/d2 0.75% used (457.88 MB of 59.58 GB), trend: +27.68 MB / 24 hours
Filesystem /mnt/d3 14.49% used (116.53 of 804.43 GB), trend: +3.17 GB / 24 hours
Filesystem /mnt/d4 14.33% used (115.29 of 804.43 GB), trend: +2.27 GB / 24 hours
Filesystem /mnt/d5 14.14% used (113.75 of 804.43 GB), trend: +1.28 GB / 24 hours
Filesystem /mnt/f1 0.11% used (34.06 MB of 29.79 GB), trend: -12.79 kB / 24 hours
Filesystem /opt 8.12% used (14.45 of 178.01 GB), trend: +391.58 kB / 24 hours
Filesystem /opt/commvault/MediaAgent64/IndexCache 3.01% used (80.77 GB of 2.62 TB), trend: -1.19 GB / 24 hours
Filesystem /var 34.81% used (7.74 of 22.25 GB), trend: -114.17 MB / 24 hours
Filesystem /var/log 36.63% used (24.45 of 66.75 GB), trend: +5.81 GB / 24 hours
Filesystem /ws/ddb 26.46% used (788.26 GB of 2.91 TB), trend: +9.08 GB / 24 hours
IPMI Sensor Summary 141 sensors - 122 OK - 19 skipped
Interface 02 [bond1], (up), MAC: 88:E9:A4:5E:C4:44, Speed: 50 GBit/s, In: 20.9 MB/s (0.33%), Out: 46.2 MB/s (0.74%)
Interface 03 [bond2], (up), MAC: 88:E9:A4:5E:C4:45, Speed: 50 GBit/s, In: 246 MB/s (3.94%), Out: 231 MB/s (3.70%)
Interface 04 [bond1.180], (up), MAC: 88:E9:A4:5E:C4:44, Speed: 50 GBit/s, In: 20.0 MB/s (0.32%), Out: 44.7 MB/s (0.72%)
Interface 05 [bond1.400], (up), MAC: 88:E9:A4:5E:C4:44, Speed: 50 GBit/s, In: 231 B/s (<0.01%), Out: 12.1 B/s (<0.01%)
Interface 08 [enpsf3], (up), MAC: 88:E9:A4:5E:C4:44, Speed: 25 GBit/s, In: 12.9 MB/s (0.41%), Out: 33.4 MB/s (1.07%)
Interface 09 [enpsf4], (up), MAC: 88:E9:A4:5E:C4:45, Speed: 25 GBit/s, In: 88.9 MB/s (2.85%), Out: 5.06 B/s (<0.01%)
Interface 10 [enpsf5], (up), MAC: 88:E9:A4:5E:E4:44, Speed: 25 GBit/s, In: 8.01 MB/s (0.26%), Out: 12.7 MB/s (0.41%)
Interface 11 [enpsf6], (up), MAC: 88:E9:A4:5E:E4:45, Speed: 25 GBit/s, In: 157 MB/s (5.04%), Out: 231 MB/s (7.40%)
Kernel Performance Process Creations: 12.18/s, Context Switches: 527929.33/s, Major Page Faults: 18.32/s, Page Swap in: 18.75/s, Page Swap Out: 19.40/s
Log /var/log/messages No error messages
Memory Total virtual memory: 68.98% - 377.91 GB of 547.85 GB
NTP Time Offset: 0.0357 ms, Stratum: 2, Time since last sync: 3 minutes 33 seconds
Systemd Service Summary Total: 181, Disabled: 22, Failed: 2
TCP Connections Established: 3237
Uptime Up since May 23 2022 13:31:55, Uptime: 170 days 6 hours
[cpu_tracking] Stop [7f56f03cb610 - Snapshot(process=posix.times_result(user=0.16000000000000014, system=0.009999999999999981, children_user=0.0, children_system=0.0, elapsed=0.16999999806284904))]
[agent] Success, execution time 2.4 sec | execution_time=2.390 user_time=0.160 system_time=0.010 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=2.220
