Will we ever get the ability to use gMSA accounts with SQL Database monitoring? Due to security reasons, we do not allow local SQL accounts, and it is configured so that every login from an application or from any other connections all use gMSA accounts. Without this ability we will never be able to monitor any SQL databases with CheckMk, and we must rely on additional applications for monitoring.
The Ideas Portal https://ideas.checkmk.com/ would be the place to add your idea so that product management may pick it up.
There is already a similar idea: https://ideas.checkmk.com/suggestions/641653/windows-agents-support-for-group-managed-service-accounts-gmsa
Or you employ Rust developers and add the feature to the source code yourself:
