But I cannot find this check at WATO -> Manual Checks? I only see 2 other Gude Checks.
There should be 4 more (gude_powerbanks, gude_relayport, gude_temp, gude_humidity)
For reference: I just click on WATO -> Manual Check and type in “gude” as a search. Only “Levels for Gude PDU Devices” shows up, which uses 2 other devices of gude as checktype (pdu_gude_8301, pdu_gude_8310)
I think I get it know, the manual SNMP checks check automatically if the snmpwalk outputs matches any given parameter to execute the script.
Sadly the gude_powerbanks script does not work for my Gude PDU. Just trying to understand how this works to adapt it to my Gude Expert Power Control 8221-1
All you have to do is add the Gude host IP/hostname depensing on your DNS with the SNMP credentials and set the datasource as SNMP and click on Save&Go to Services.
You should see the GUDE based checks added to the inventory.
BTW, here you find them:
