Hello folks,
I have a check_http working fine with check_mk 1.6.0p22 CEE but gives an error with check_mk 2.0.0p6 CEE(HTTP CRITICAL - No data received from host). The check_http returns a 200 on the OS prompt. see below.
OMD[asd3]:~$ /omd/versions/2.0.0p6.cee/lib/nagios/plugins/check_http -u ‘/brh-webservice/BrhWebService-v1?wsdl’ --ssl -t 300 -A ‘TNO GDN Nagios Webservice check’ -J ‘/etc/ssl/ebn/ebn.crt’ -K /etc/ssl/ebn/ebn.key -r ‘zoekBoorgatenRequest’ --sni -p 443 -H www.yyyyyyy.nl
HTTP OK: HTTP/1.1 200 OK - 11177 bytes in 0.061 second response time |time=0.061039s;;;0.000000;300.000000 size=11177B;;;0
WATO config:
Host name is XXXXXX
Service name: Webservice Boorgaten service EBN - WSDL query only_bis
Host settings:
Hosts name / IP address: www.yyyyyyy.nl
TCP Port: 443
Virtual host: www.yyyyyyy.nl
Mode of the Check: Check the URL,
URI to fetch (default is /): /brh-webservice/BrhWebService-v1?wsdl
Use SSL/HTTPS for the connection: Use SSL with auto negotiation
Seconds before connection times out: 300 sec
User Agent: TNO GDN Nagios Webservice check
Additional header lines:
-J /etc/ssl/ebn/ebn.crt
Regular expression to expect in content: BoorgatenRequest, off, off, off
