I monitor juniper mx480 for checkmk but it not show full snmp, (The interfaces are fully displayed)
Can someone tell me, am I missing something? Juniper device orther (ex4600, 4300, MX204) show full snmp.
Thanks to everyone for the support!
What do you mean with “full snmp”?
If you miss the information for cpu, memory or fans then the problem is that CMK has no checks for this special juniper device.
You can take a look at your device what is the value of the following OID “.1.3.6.1.2.1.1.2.0” if it begins with “.1.3.6.1.4.1.2636.1.1.1” then it should normally found by the juniper checks.
Not show interface of MX480, I don’t see port interface ae0 or ae1
Then you need to modify the interface discovery rule.
What type are these interfaces?
Oh that port interface “ae”, so I need to modify the interface discovery rule in CMK?
The interface discovery rule defines what interface types should be found.
Beside the interface state.
Default settings
You can edit the list on the right side with types from the left.
For a test you can add all types from the left and check if your interfaces are now found.
Thank you very much!, I’ve found ! Have a nice day!
