I need the possibility to hide these kinds of warning alerts attached in the picture. Please can you tell me the guide to hide them? Thank you.
Not so clear what you really want but check out the rule “Periodic service discovery”
BR
Michael
Hi @r-soneparit
there is a rule for that in setup:
Setup - Services - Periodic service discovery
You may set the desired states there.
The missing host labels can be solved by a (bulk) discovery of that hosts, there you discover and save the labels, that are reported as missing in the output of the discovery check.
These warnings tell you that there are new things to monitor resp. new host labels discovered. You should go into the service configuration and add them.
