I have several Postgres databases I would like to monitor using the provided plugin.
But they run within docker containers.
If I install the plugin in the docker host (machine) it does not see the database within the container.
Shall I then install the plugin within the container too?
BTW, I have the same exact question with a MySQL database, also installed within a docker container.
If nothing has changed since my last time i answered some question like this.
You need to install a CMK agent and the mk_postgres inside the container.
In case you only want to monitor the accessibility and some own queries, then you can also use the rule " Check SQL Database".
