I was reading this:
- Do I have to create it manually ?
- Can’t this be rolled out via bakery ?
If I give a regex for a particular file, is there a way to negate it ?
I was reading this:
for this check you don’t need to deploy a plugin. You have to setup the bakery rule “Count, size and age of files (Linux, Windows)”.
Karl
Or if you use the RAW edition you have to manually configure the agent to monitor the wanted files.
I don’t think so as this is also no regex. For the fileinfo check you only can define globing pattern.
