is there anyone out there who is monitoring a Unify OpenScape Cordless IP V2 DECT station? With the Event Console?
I’m currently trying to monitor the DECT stations for outages but can’t find anything helpful on the internet…
Regards
CheckMan
tavanez
(Pedro Tavanez)
February 20, 2020, 2:09pm
2
Hi @CheckMan ,
Will it send snmp traps ? If so upload the mibs to the event console and then create rules to parse the incoming traps.
If not traps, try to create different rules that match the incoming strings and assign it to a host.
Thanks for your reply @tavanez !
Yes, it sends SNMP traps. mkeventd.log says:
2020-02-28 11:07:13,854 [15] [cmk.mkeventd.EventServer.snmp] Trap received from XX.XX.XX.XX:51832. Checking for acceptance now.
2020-02-28 11:07:13,860 [15] [cmk.mkeventd.EventServer.snmp] Trap (v3) dropped from XX.XX.XX.XX: {‘errorIndication’: InvalidMsg()}
(I anonymised my IPs)
Is there any way to debug further?
Regards
CheckMan
