Hi all ,
I’m running a Kubernetes cluster in Azure and I am monitoring the pod’s it in check_mk .The POD’s contain a docker image on which the check_mk agent is installed with some additional custom check’s.
Is there a way for the Kubernetes Special Agent to run the check_mk agent on the docker image of the POD and get the response as piggyback data or do I need to expose an POD service (ssh or port 6556) on the container and get it directly?
Thanks in advance!
