Hi there. I try to have kubernetes inventories automatically added to different Folders. Therefore i created multiple Dynamic Host Management daemons and let each only create hosts with a specific name in it. That suddenly leads to a situation where the dcds do lock each other. I get errors all the time because some changes couldn’t be activated because other changes are currently being activated.
Am i doing that right?
Or is there maybe another function which i can use to move the hosts into their target folders after being created by the automatic kubernetes inventory?
Inside of one DCD you can configure already what you want. Different matches and every match for it’s own target folder.
I have done this for a large kubernetes and sort all the objects depending on the name.
I know the option but the problem for me was that all the dcd jobs locked themselve out of each other because they all try to activate changes at the same time. Have you spreaded the pause times of these jobs?
