HP Raid Controller mkp plugin
Hi!
I installed a mkp in my site version 1.6raw which seemed to work.
But after the installation it looks like nothing happened I can’ see any sign of it.
Shouldn’t it show uo in the list of available plugins?
The name of the mkp is HP SmartArray Checks.
Sorry it may be a stupid question but I am stuck here.
Thank you all for your help!
Hi @antiager
It should show up in the list of installed mkp's with mkp list. You can then
see more info for the package you installed with mkp show <PACKAGE> and list the files it
contains with mkp list <PACKAGE>.
HTH,
Thomas
You need to deploy the agent plugin. With the Enterprise Edition use the agent bakery. With the Raw Edition deploy the file from $OMD_ROOT/local/share/check_mk/agents/plugins with whatever method you use to deploy files.
Agent plugins from extensions do not show up on the “Agent files” page unfortunately.
Tank you!!
It works!!!
