I have many HP switches which I’m auto-discovering from an IP range in to CheckMK 1.6.0 Raw. This is using SNMPv2 and a specific community string.
The switches are all being discovered and all the interfaces, CPU, fans, memory, uptime are all successfully graphing and logging which is great. (Using hp_procure_sensors etc)
However, I don’t know how to use the hostname specified in the switches in CheckMK instead of just the IP address. It is visible in both snmp_info and mgmt_snmp_info plugins, for example:
ProCurve J9145A 2910al-24G Switch, revision W.14.38, ROM W.14.04 (/sw/code/build/sbm(t4a)), Room C, Room C Switch 1, ITSupport
(Room C is the snmp hostname, Room C Switch 1 is the location and ITSupport is the contact)
But I don’t know how to extract that and create a rule to rename the host in CheckMK automatically.
Please can someone point me in the right direction?
Many thanks
Lewis.
