we currently have distributed monitoring environment with a handful of remote monitoring nodes.
this is on 2.1.0p9.cre
how exactly does CheckMK Backup work with relation to this?
i.e. would I have to log into each node and configure a backup job?
Setup → Maintenance → Site Backup requires I setup a Backup Target -
I try to create a folder called /opt/omd/backups/ which is local to the check_mk server and when I use this in the destination I get an error: “Please enter a valid absolut pathname with / as a path separator” –
other attempts give me “you have to provide a canonical path” — not sure what I’m doing wrong…
is there a way to does the configuration of Backup specify retention period ?
i.e. I’d like to schedule nightly backup, but only keep the last 30days worth…
thanks! I have confirmed this behaviour and I guess it makes sense to setup individual jobs for each day…
7-day retention is probably more than enough.
hopefully someone can help with #1 and #2.
I’m not sure if I need to log into each distributed node and setup the same, or is everything safely backed up from the master node?
as for #2, I used /tmp and it worked, but I know this isn’t the final/expected location… will test further and update.
I’ve had the same error message. If I remember correctly, the final slash seems to confuse Checkmk and leads to this (equally confusing) error message. Try /opt/omd/backups without the trailing /.
I’d call that a bug, since the path should work with a trailing slash just the same.
Strange. Perhaps because it’s below /opt/omd (which I would leave alone).
I’m using /var/backups/checkmk/mysite without any problem.
The “Mountpoint” option needs to be off since it’s just a directory on the local disk.
And make sure the site user has proper permissions on the directory
(chown mysite:mysite /var/backups/checkmk/mysite).
