Inconsistencies of Docker images tags
I have a question regarding the way checkmk raw docker images are being tagged. On Docker the regular tagging convention was yyyy-mm-dd. Suddenly that changed with the release of a new patch ([2.1.0p19]) but then later a new tag [2023.01.12] shows up that is bigger than the latest tag. Does anyone understand the logic behind the tagging process? I would appreciate any hint in this regard.
Thank you
yyyy-mm-dd → daily builds, not stable
[2.1.0p19] → stable. You should use this.
