Hello
How can I integrate a dashboard with other sites? Do I have to copy a file and which one?
Regards
Hans-Peter
you can try to copy the file ~/var/check_mk/web//user_dashboards.mk to an other site and test it there. But keep in mind: If there are hard links to filter of hosts an services, the dashboard can fail.
So try it.
Regards, >christian
What do you exactly like to do?
Do you like to show the same configured dashboards with information from the other site?
Or do you like to show the dashborad with information from the original site on the other site?
You can include parts of the dashborad via a automation user into other site’s dashboards via the url to the dashboard snapins.
If you like to have same configured dashboards around you sites you can try the method mentioned by @ChristianM but it could have side effects.
