CMK version: Checkmk Raw Edition 2.1.0-2022.05.27 OS version: docker CE
After I click Y to register tls I get the below error. I am using the automation account and my password is correct!
> Y
[2022-06-01 16:52:46.689883 +10:00] ERROR [cmk_agent_ctl] src\main.rs:29: Error pairing with checkmk:443/cmk
Caused by:
Request failed with code 401 Unauthorized: <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>401 Unauthorized</title>
</head><body>
<h1>Unauthorized</h1>
<p>This server could not verify that you
are authorized to access the document
requested. Either you supplied the wrong
credentials (e.g., bad password), or your
browser doesn't understand how to supply
the credentials required.</p>
</body></html>
Do not explicitely specify the port of the web interface/REST API (in your case 443). Use the port of the Agent Receiver which is 8000 or 8001 instead or leave the port blank for auto detection.
(There have been lots of misunderstandings on this ports thing, I am in progress of updating the articles for the Linux and Windows agent)
Is the Agent Receiver running? Is port 8000 available from the host where you run cmk-agent-ctl register? To check for Agent Receiver, run (as site user):
omd config show | grep AGENT_RECEIVER
To check whether the host can reach the Agent Receiver, run on the host:
DOH I forgot I had set a custom port for agent receiver as i had a conflict for 8000 on my docker host. I was using 8101 so after i set this it worked perfectly. It would be good if after you run the cmk-agent-ctl register you get a positive validation in the command output like OK or Registered!
