CMK version: 2.1.0p17
OS version: Linux 20.04 Ubuntu utilizing Checkmk as a Docker container
I am not able to see any services of of my special AWS agent on my Checkmk. I got one notification from service “AWS Exceptions” that stated check plugin received no monitoring data.
I have followed the setup guide for the special agent as well as the host and AWS configuration. I am really at a blank at the moment on why this is not pulling any information. Below is the output of the cmk debug.
The only thing that is different about this setup as opposed to a conventional setup is just that it is running in a docker container.
cmk -vvI --debug --verbose aws-01
Discovering services and host labels on: aws-01
aws-01:
- FETCHING DATA
Source: SourceType.HOST/FetcherType.PROGRAM
[cpu_tracking] Start [7f99a3d210a0]
[ProgramFetcher] Fetch with cache settings: DefaultAgentFileCache(aws-01, base_path=/omd/sites/cmk/tmp/check_mk/data_source_cache/special_aws, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Does not exist)
Calling: /omd/sites/cmk/share/check_mk/agents/special/agent_aws ‘–regions’ ‘us-east-2’ ‘–global-services’ ‘ce’ ‘–services’ ‘ec2’ ‘–ec2-limits’ ‘–hostname’ ‘aws-01’
STDIN (first 30 bytes): {“access_key_id”: "… (total 105 bytes)
[cpu_tracking] Stop [7f99a3d210a0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.61, children_system=0.09, elapsed=1.4800000004470348))]
[cpu_tracking] Start [7f99a36c0070]
[PiggybackFetcher] Fetch with cache settings: NoCache(aws-01, base_path=/omd/sites/cmk/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=True, use_outdated=False, simulation=False)
No piggyback files for ‘aws-01’. Skip processing.
[cpu_tracking] Stop [7f99a36c0070 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))] - PARSE FETCHER RESULTS
→ Not adding sections: Agent exited with code 1:
No persisted sections
→ Add sections: []
Received no piggyback data
Received no piggyback data - ANALYSE DISCOVERED HOST LABELS
Trying host label discovery with:
SUCCESS - Found no new host labels - ANALYSE DISCOVERED SERVICES
- EXECUTING DISCOVERY PLUGINS (0)
Trying discovery with:
SUCCESS - Found no new services
