@andreas-doehler @simon-mueller Thank you for reply. Sorry I know this got delayed. Had to prioritize other tasks. Again the issue is still the same. But this time i will provide more info.
Here is the plugin
import pprint
bgp_peer_inventory_adminstates = [ 2 ]
def discover_bgp(section):
for identifier, peerstate, adminstate, version, localaddr, \
remoteaddr, remoteas, peerinupdates, peeroutupdates, lasterror, peeresttime in section:
yield Service(item=remoteaddr)
def sec2hr(seconds):
m, s = divmod(seconds, 60)
h, m = divmod(m, 60)
d, h = divmod(h, 24)
hr = "%dd %02dh %02dm %02ds" % (d, h, m, s)
return(hr)
def bgp_peerstate(st):
names = { '0' : 'none',
'1' : 'idle',
'2' : 'connect',
'3' : 'active',
'4' : 'opensnet',
'5' : 'openconfirm',
'6' : 'established' }
return names.get(st, st)
def bgp_adminstate(st):
names = { '1' : 'stop',
'2' : 'start', }
def bgp_errors(key1, key2):
names = {}
names["0"] = { "0" : "NO ERROR"}
names["1"] = { "0" : "Message",
"2" : "Connection Not Synchronized",
"3" : "Bad Message Length",
"4" : "Bad Message Type",
names["2"] = { "0" : "OPEN",
"1" : "Unsupported Version Number",
"2" : "Bad Peer AS",
"3" : "Bad BGP Identifier",
"4" : "Unsupported Optional Parameter",
"5" : "Authentication Failure",
"6" : "Unacceptable Hold",
names["3"] = { "0" : "UPDATE",
"1" : "Malformed Attribute List",
"2" : "Unrecognized Well-known Attribute",
"3" : "Missing Well-known Attribute",
"4" : "Attribute Flags Error",
"5" : "Attribute Length Error",
"6" : "Invalid ORIGIN Attribute",
"7" : "AS Routing Loop",
"8" : "Invalid NEXT_HOP Attribute",
"9" : "Optional Attribute Error",
"10" : "Invalid Network Field",
"11" : "Malformed AS_PATH",
names["4"] = { "0" : "Hold Timer Expired",}
names["5"] = { "0" : "Finite State Machine Error",}
names["6"] = { "0" : "Administratively Shutdown",
"1" : "Max Prefix Reached",
"2" : "Peer Unconfigured",
"3" : "Administratively Reset",
"4" : "Connection Rejected",
"5" : "Other Configuration Change",
return names[key1].get(key2)
def ByteToHex(byteStr):
return ''.join( [ "%02X " % ord(x) for x in byteStr ] ).strip()
def check_bgp(item, section):
#print(len(section))
length_range = len(section)
for i in range(length_range):
# print(i)
# print(section[i])
# print(localaddr, remoteaddr, item)
if remoteaddr == item:
output = "BGP Peer: %s Adminstate: %s " % (identifier, bgp_adminstate(str(adminstate)))
lasterrorhex = ByteToHex(lasterror)
byte1, byte2 = lasterrorhex.split()
lerr = int(byte1, 16)
lsuberr = int(byte2, 16)
lasterrorstr = bgp_errors(str(lerr), str(lsuberr))
peeresttimehr = sec2hr(int(peeresttime))
#print(typeof(peerstate))
if int(peerstate) == 1:
severity = "CRITICAL"
s = State.CRIT
output += "PeerState: %s(!!) Version: %s LocalAddr: %s \
RemoteAddr: %s RemoteAS: %s LastError: %s PeerEstablishedTime: %s" % \
(bgp_peerstate(str(peerstate)), version, localaddr, remoteaddr, remoteas, lasterrorstr, peeresttimehr )
elif int(peerstate) in ['2', '3', '4', '5']:
severity = "WARNING"
s = State.WARN
output += "PeerState: %s(!) Version: %s LocalAddr: %s \
elif int(peerstate) == 6:
severity = "OK"
s = State.OK
output += "PeerState: %s Version: %s LocalAddr: %s \
else:
severity = "UNKNOWN"
s = State.UNKNOWN
output = "Invalid Output from Agent"
infotext = severity + " - " + output
section = section.pop(i)
yield from check_levels(int(peeresttime), metric_name = 'peer_est_time')
yield Metric(name="Peerinupdates", value=int(peerinupdates))
yield Metric(name="Peeroutupdates", value=int(peeroutupdates))
yield Metric(name="Peerstate", value=int(peerstate))
yield Result(
state = s,
summary = infotext)
return
# return(3, "UNKNOWN - item not found in snmp data")
register.snmp_section(
name = "fortigate_bgp_peer",
detect = exists(".1.3.6.1.2.1.1.1.0"),
fetch = SNMPTree(
base = '.1.3.6.1.2.1.15.3.1',
oids = [
'1', # "bgpPeerIdentifier"
'2', # "bgpPeerState"
'3', # "bgpPeerAdminStatus"
'4', # "bgpPeerNegotiatedVersion"
'5', # "bgpPeerLocalAddr"
'7', # "bgpPeerRemoteAddr"
'9', # "bgpPeerRemoteAs"
'10', # "bgpPeerInUpdates"
'11', # "bgpPeerOutUpdates"
'14', # "bgpPeerLastError"
'16', # "bgpPeerFsmEstablishedTime"
register.check_plugin(
service_name = "BGP Peer %s",
discovery_function = discover_bgp,
check_function = check_bgp
Here is the output I get from CLI
OMD[~~~]:~$ cmk --debug --detect-plugins=fortigate_bgp_peer -v ~~~~~~~
Checkmk version 2.0.0p3
+ FETCHING DATA
No piggyback files for '~~~~~~~'. Skip processing.
No piggyback files for '10.0.129.10'. Skip processing.
+ PARSE FETCHER RESULTS
Received no piggyback data
BGP Peer 10.214.112.1 750919.00, OK - BGP Peer: 155.130.6.229 Adminstate: start PeerState: established Version: 4 LocalAddr: 10.214.112.10 RemoteAddr: 10.214.112.1 RemoteAS: 65001 LastError: Hold Timer Expired PeerEstablishedTime: 8d 16h 35m 19s
BGP Peer 10.214.120.1 214301.00, OK - BGP Peer: 155.130.6.229 Adminstate: start PeerState: established Version: 4 LocalAddr: 10.214.120.10 RemoteAddr: 10.214.120.1 RemoteAS: 65001 LastError: Hold Timer Expired PeerEstablishedTime: 2d 11h 31m 41s
BGP Peer 10.215.112.1 1850272.00, OK - BGP Peer: 209.170.215.19 Adminstate: start PeerState: established Version: 4 LocalAddr: 10.215.112.10 RemoteAddr: 10.215.112.1 RemoteAS: 65001 LastError: NO ERROR PeerEstablishedTime: 21d 09h 57m 52s
BGP Peer 10.215.120.1 214300.00, OK - BGP Peer: 209.170.215.19 Adminstate: start PeerState: established Version: 4 LocalAddr: 10.215.120.10 RemoteAddr: 10.215.120.1 RemoteAS: 65001 LastError: Hold Timer Expired PeerEstablishedTime: 2d 11h 31m 40s
[snmp] Success, execution time 0.6 sec | execution_time=0.570 user_time=0.250 system_time=0.050 children_user_time=0.000 children_system_time=0.000 cmk_time_snmp=0.270 cmk_time_agent=0.000
In the UI I can see these services under service configuration like below
But in the Host status detail I can’t see this
I think the issue is inside the plugin can you please point out where I did a mistake?
Thank you,
Shivdevkumar
