check_mk service discovery for Juniper SRX 1500 identifies some file systems (such as “/”) as 100% and raises critical alert
as per vendor, the architecture of this device isn’t like traditional Unix host, and therefore should be considered normal behaviour – aside from removing the service check, anything else that can be done?
No, that’s not Checkmk’s fault. You should ignore these services.
ok, let me just keep them ignored, thx
