I’m trying to build a check for twamp in juniper devices.
my issue is for now with the snmp_info section.
I’m trying to use the .endswith() function but it gives error:
Error in plugin file /omd/sites/monitor/share/check_mk/checks/juniper_twamp: ‘tuple’ object has no attribute ‘endswith’
my code:
'snmp_info': ( ".1.3.6.1.4.1.2636.3.77.1.1.1.1", [ 2, #jnxTwampResSampleValue 3, #jnxTwampResSampleDate ],".*").endswith( [ "1", #roundTripTime "2", #rttJiter "5", #egress jiter "8", #ingress jiter ]),
The termination of the OID string is what defines the type of metric.
So I would like to gather the sample value and date for each metric type.
The final goal is to build some graphics with this.
How can I do the same without the .endswith function ?
I’m also trying to use the wildcard “.*” without success.
Thanks in advance.
