Hi everyone,
has anyone experienced the following phenomena, or give me a hint of what could be the cause, or any suggestion to solve this. I really appreciate your help!
We are running Check_MK Enterprise 1.4.0p34.cee on Ubuntu 18.0.4 LTS and plan to upgrade Check_MK and move to a new server 20.0.4 LTS. The first step is to update 1.4.0 to
check-mk-enterprise-1.6.0p28_0.bionic_amd64.deb
- check-mk-enterprise-1.6.0p28_0.bionic_amd64.deb installation ok
- omd update – suprisingly fast (see below)
- omd start – KeyError: ‘LIVESTATUS_TCP_TLS’
Note: if I create a new site using the version 1.6.0p28.cee everything is fine.
Thanks in advance
Phan
PS. console messages
Updating site 'cgkmon' from version 1.4.0p34.cee to 1.6.0p28.cee...
* Updated .profile
* Updated .bashrc
* Installed dir etc/stunnel
* Installed dir etc/bash_completion.d
* Installed dir etc/rrdcached.d
* Updated etc/rrdcached.conf
* Updated etc/nagios/conf.d/check_mk_templates.cfg
* Updated etc/nagios/nagios.d/logging.cfg
* Updated etc/nagios/nagios.d/freshness.cfg
* Installed link etc/rc.d/85-stunnel
* Installed link etc/rc.d/85-dcd
* Updated etc/apache/apache.conf
* Installed file etc/apache/conf.d/01_wsgi.conf
* Updated etc/apache/conf.d/omd.conf
* Installed file etc/apache/conf.d/security.conf
* Installed file etc/cron.d/cmk_cleanup_crashed_checks
* Installed file etc/cron.d/cmk_cleanup_piggyback
* Updated etc/init.d/nagios
* Updated etc/init.d/liveproxyd
* Updated etc/init.d/crontab
* Updated etc/init.d/apache
* Updated etc/init.d/rrdcached
* Updated etc/init.d/cmc
* Installed file etc/init.d/stunnel
* Installed file etc/init.d/dcd
* Updated etc/init.d/mknotifyd
* Updated etc/init.d/mkeventd
* Installed file etc/logrotate.d/stunnel
* Installed file etc/logrotate.d/dcd
* Installed file etc/stunnel/server.conf
* Updated etc/check_mk/apache.conf
* Updated etc/nagvis/nagvis.ini.php
* Updated etc/nagvis/conf.d/omd.ini.php
* Updated etc/pnp4nagios/npcd.cfg
* Updated etc/mk-livestatus/xinetd.conf
* Updated etc/init-hooks.d/README
* Updated etc/dokuwiki/dokuwiki.php
* Updated etc/dokuwiki/mime.conf
* Updated etc/dokuwiki/local.php
* Installed dir local/share/check_mk/locale
* Installed dir local/share/check_mk/web/htdocs/themes
* Installed dir var/check_mk/reports
* Installed dir var/check_mk/reports/archive
* Installed link var/dokuwiki/lib/plugins/cli.php
* Vanished var/icinga
* Vanished local/share/icinga/htdocs
* Vanished local/lib/icinga
* Vanished etc/icinga/icinga.d/eventhandler.cfg
* Vanished etc/icinga/icinga.d/dependency.cfg
* Vanished etc/icinga/icinga.d/obsess.cfg
* Vanished etc/icinga/icinga.d/mk-livestatus.cfg
* Vanished etc/icinga/icinga.d/misc.cfg
* Vanished etc/icinga/icinga.d/retention.cfg
* Vanished etc/icinga/icinga.d/logging.cfg
* Vanished etc/icinga/icinga.d/timing.cfg
* Vanished etc/icinga/icinga.d/tuning.cfg
* Vanished etc/icinga/icinga.d/omd.cfg
* Vanished etc/icinga/icinga.d/freshness.cfg
* Vanished etc/icinga/icinga.d/flapping.cfg
* Vanished etc/icinga/ssi/README
* Vanished etc/icinga/ssi/status-header.ssi
* Vanished etc/icinga/ssi/extinfo-header.ssi
* Vanished etc/icinga/cgiauth.cfg
* Vanished etc/icinga/cgi.cfg
* Vanished etc/icinga/apache.conf
* Vanished etc/icinga/icinga.cfg
* Vanished etc/icinga/config.inc.php
* Vanished etc/icinga/idomod.cfg-sample
* Vanished etc/icinga/resource.cfg
* Vanished etc/icinga/conf.d
* Vanished etc/init.d/icinga
* Vanished etc/apache/conf.d/01_python.conf
* Vanished etc/rc.d/80-icinga
Finished update.
root@nagios3:/tmp# omd start cgkmon
Creating temporary filesystem /omd/sites/cgkmon/tmp...OK
File "/usr/bin/omd", line 65, in <module>
omdlib.main.main()
File "/omd/versions/1.6.0p27.cee/lib/python/omdlib/main.py", line 4776, in main
command_function(site, args, command_options)
File "/omd/versions/1.6.0p27.cee/lib/python/omdlib/main.py", line 4442, in <lambda>
lambda site, args, opts: main_init_action(site, "start", args, opts), [
File "/omd/versions/1.6.0p27.cee/lib/python/omdlib/main.py", line 3443, in main_init_action
exit_status = init_action(site, command, args, options)
File "/omd/versions/1.6.0p27.cee/lib/python/omdlib/main.py", line 2329, in init_action
prepare_and_populate_tmpfs(site)
File "/omd/versions/1.6.0p27.cee/lib/python/omdlib/main.py", line 1612, in prepare_and_populate_tmpfs
_create_livestatus_tcp_socket_link(site)
File "/omd/versions/1.6.0p27.cee/lib/python/omdlib/main.py", line 3373, in _create_livestatus_tcp_socket_link
target = "live-tls" if site.conf["LIVESTATUS_TCP_TLS"] == "on" else "live"
KeyError: 'LIVESTATUS_TCP_TLS'
root@nagios3:/tmp#
