Hello there, after updating CMK Appliance to 1.6.0p20 and baking new Agents, our Docker hosts has the following error for all Containers for Service Check_MK Discovery:
KeyError ('percpu_usage')
Trace:
File “/omd/sites/mobilfunk/lib/python/cmk_base/decorator.py”, line 58, in wrapped_check_func
status, infotexts, long_infotexts, perfdata = check_func(hostname, *args, **kwargs)
File “/omd/sites/mobilfunk/lib/python/cmk_base/discovery.py”, line 426, in check_discovery
on_error=“raise”)
File “/omd/sites/mobilfunk/lib/python/cmk_base/discovery.py”, line 1061, in _get_host_services
return _get_node_services(host_config, ipaddress, sources, multi_host_sections, on_error)
File “/omd/sites/mobilfunk/lib/python/cmk_base/discovery.py”, line 1069, in _get_node_services
File “/omd/sites/mobilfunk/lib/python/cmk_base/discovery.py”, line 1102, in _get_discovered_services
File “/omd/sites/mobilfunk/lib/python/cmk_base/discovery.py”, line 838, in _discover_services
check_plugin_name, on_error):
File “/omd/sites/mobilfunk/lib/python/cmk_base/data_sources/host_sections.py”, line 299, in _update_with_parse_function
return parse_function(section_content)
File “/omd/sites/mobilfunk/share/check_mk/checks/docker_container_cpu”, line 42, in parse_docker_container_cpu
parsed[“num_cpus”] = len(raw[‘cpu_usage’][‘percpu_usage’])
I’m currently working on this problem. Could you share some information about your setup and the containers so I can reproduce this problem locally? Is the problem still present?
What does docker stats --no-stream report for the containers?
What Operation System do you use for the docker host?
