Kubernetes monitor PVC
We have CMK Enterprise edition 2.1.0p19 and we are able to check all K8S cluster resource with the exception to monitor PVC resource.
We need to know if there are way to monitor PVC size usage in every k8s pod?
K8S version 1.23.7.
Storage Class: rook-ceph and NFS.
We found the follow plugin Kubernetes: Persistent Volume Claim but there are not instructions about how implemented.
Any idea or help?
Thans and regards.
if i remember it correct, this feature will come in checkmk 2.2.
Thank you very much for the information.
Best regards
hi,
is there a solution for version 2.1
best regars
No, you will have to wait for version 2.2
and the same graphs, metrics as you have with the normal filesystem check
When will be published the version 2.2 ?
We are currently stabilizing the 2.2.0 branch (GitHub - tribe29/checkmk at 2.2.0)
We will share our plans on the release pretty soon.
