We are trying to setup monitoring for the kubernetes with the available documentation , & been getting the below error
Reason: Forbidden
HTTP response headers: HTTPHeaderDict({‘Cache-Control’: ‘no-cache, private’, ‘Content-Type’: ‘application/json’, ‘X-Content-Type-Options’: ‘nosniff’, ‘Date’: ‘Fri, 11 Sep 2020 06:56:49 GMT’, ‘Content-Length’: ‘269’})
HTTP response body: {“kind”:“Status”,“apiVersion”:“v1”,“metadata”:{},“status”:“Failure”,“message”:“forbidden: User “system:serviceaccount:check-mk:check-mk” cannot get path “/k8s/clusters/kubernetes/apis/storage.k8s.io/v1/storageclasses””,“reason”:“Forbidden”,“details”:{},“code”:403}
Which version of Kubernetes are you using? I had issues with 1.18 as they changed the API and the Python package everyone uses, is not up-to-date yet.
Hey Martin ,
Client Version: v1.15.4
Server Version: v1.15.12
Hi
the http status code says 403. That indicates that the service account which has to be created has not the sufficient rights to access the cluster
BR
Thomas
itsmebalaji
(Itsmebalaji)
September 14, 2020, 12:01pm
5
Hi Thoma ,
I just followed the instructions available as per the check_mk document & used the rbac available in github , still struggling to pass the sufficient access
even tried the default service account , but of no luck
Did you convert the Cert and token correctly as described?
BR
system
(system)
Closed
October 16, 2020, 11:38pm
7
