**CMK version: 2.1.0b5.cre ** OS version: Ubuntu 20.04
We try to monitor a kubernetes cluster, but we always get this errors.
Is it realy a license problem?
When we try to search for the kubernetes service at the host, there is no output.
We used this manual
(Monitoring Kubernetes)
cmk --debug -vvn
Precompile /omd/sites/mysite/local/share/check_mk/checks/license.include to /omd/sites/mysite/var/check_mk/precompiled_checks/local/license.include
Error in check include file /omd/sites/mysite/local/share/check_mk/checks/license.include: [Errno 2] No such file or directory: '/omd/sites/mysite/local/share/check_mk/checks/license.include'
Error in plugin file /omd/sites/mysite/local/share/check_mk/checks/veeam_o365licenses: [Errno 2] No such file or directory: '/omd/sites/mysite/local/share/check_mk/checks/license.include'
Trying to acquire lock on /omd/sites/mysite/var/check_mk/crashes/base/fb1a164a-e114-11ec-b076-9755f0b37a35/crash.info
Got lock on /omd/sites/mysite/var/check_mk/crashes/base/fb1a164a-e114-11ec-b076-9755f0b37a35/crash.info
Releasing lock on /omd/sites/mysite/var/check_mk/crashes/base/fb1a164a-e114-11ec-b076-9755f0b37a35/crash.info
Released lock on /omd/sites/mysite/var/check_mk/crashes/base/fb1a164a-e114-11ec-b076-9755f0b37a35/crash.info
File "/omd/sites/mysite/bin/cmk", line 79, in <module>
errors = config.load_all_agent_based_plugins(check_api.get_check_api_context)
File "/omd/sites/mysite/lib/python3/cmk/base/config.py", line 1526, in load_all_agent_based_plugins
errors.extend(load_checks(get_check_api_context, filelist))
File "/omd/sites/mysite/lib/python3/cmk/base/config.py", line 1606, in load_checks
did_compile |= load_check_includes(f, check_context)
File "/omd/sites/mysite/lib/python3/cmk/base/config.py", line 1723, in load_check_includes
did_compile |= load_precompiled_plugin(include_file_path, check_context)
File "/omd/sites/mysite/lib/python3/cmk/base/config.py", line 1897, in load_precompiled_plugin
py_compile.compile(path, precompiled_path, doraise=True)
File "/omd/sites/mysite/lib/python3.9/py_compile.py", line 142, in compile
source_bytes = loader.get_data(file)
File "<frozen importlib._bootstrap_external>", line 1039, in get_data
FileNotFoundError: [Errno 2] No such file or directory: '/omd/sites/mysite/local/share/check_mk/checks/license.include'
web.log
2022-05-31 20:53:47,419 [30] [cmk.web.automations 3004147] 'check_mk --automation try-inventory @noscan myhost.de' returned 'Error in check include file /omd/sites/mysite/local/share/check_mk/checks/license.include: [Errno 2] No such file or directory: '/omd/sites/mysite/local/share/check_mk/checks/license.include'
This was just a try… rolled back to 2.1 stable.
And found the same line while up/downgrading:
“[Errno 2] No such file or directory: '/omd/sites/mysite/local/share/check_mk/checks/license.include”
Deleted all items in this folder and now i have a better error for kubernetes monitoring.
+ FETCHING DATA
Source: SourceType.HOST/FetcherType.PROGRAM
[cpu_tracking] Start [7fb76f3a7d60]
[ProgramFetcher] Fetch with cache settings: DefaultAgentFileCache(checkmk.services.staging.mysite.de, base_path=/omd/sites/mysite/tmp/check_mk/data_source_cache/special_kube, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Does not exist)
Calling: /omd/sites/mysite/share/check_mk/agents/special/agent_kube --pwstore=4@0@stagingkubernetes '--cluster' 'staging' '--token' '**********************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************' '--monitored-objects' 'deployments' 'daemonsets' 'statefulsets' 'namespaces' 'nodes' 'pods' '--cluster-aggregation-exclude-node-roles' 'control-plane' 'infra' '--api-server-endpoint' 'https://checkmk.services.staging.mysite.de:443' '--verify-cert-api' '--api-server-proxy' 'FROM_ENVIRONMENT' '--cluster-collector-endpoint' 'http://checkmk.services.staging.mysite.de:30035' '--verify-cert-collector' '--cluster-collector-proxy' 'FROM_ENVIRONMENT'
[cpu_tracking] Stop [7fb76f3a7d60 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.75, children_system=0.11, elapsed=1.030000001192093))]
[cpu_tracking] Start [7fb76f3a7460]
[PiggybackFetcher] Fetch with cache settings: NoCache(checkmk.services.staging.mysite.de, base_path=/omd/sites/mysite/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=True, use_outdated=False, simulation=False)
No piggyback files for 'checkmk.services.staging.mysite.de'. Skip processing.
[cpu_tracking] Stop [7fb76f3a7460 - Snapshot(process=posix.times_result(user=0.0, system=0.010000000000000009, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
-> Not adding sections: Agent exited with code 1: 404, Reason: Not Found, Message: None
No persisted sections
-> Add sections: []
Received no piggyback data
[cpu_tracking] Start [7fb76f36cc40]
value store: synchronizing
Trying to acquire lock on /omd/sites/mysite/tmp/check_mk/counters/checkmk.services.staging.mysite.de
Got lock on /omd/sites/mysite/tmp/check_mk/counters/checkmk.services.staging.mysite.de
Releasing lock on /omd/sites/mysite/tmp/check_mk/counters/checkmk.services.staging.mysite.de
Released lock on /omd/sites/mysite/tmp/check_mk/counters/checkmk.services.staging.mysite.de
[cpu_tracking] Stop [7fb76f36cc40 - Snapshot(process=posix.times_result(user=0.020000000000000018, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.019999999552965164))]
[special_kube] Agent exited with code 1: 404, Reason: Not Found, Message: None(!!), execution time 1.1 sec | execution_time=1.050 user_time=0.020 system_time=0.010 children_user_time=0.750 children_system_time=0.110 cmk_time_ds=0.170 cmk_time_agent=0.000
There should be something wrong with thr kubernetes cluster…
