out of the blue yesterday livestatus encryption one one of my slaves just stopped working. Gave me the following error:
Cannot connect to 'tcp:server:6557': ('_ssl.c:711: The handshake operation timed out',). The encryption settings are probably wrong.
It’s definitely something with the site because if I create a new site with the same settings it works just fine. Is there any way to recreate the encryption set up from scratch? I’m using the 1.4.7 virtual appliance and am running 1.6.0 p9 cee.
I’ve been getting these at random since I started using encryption. If it takes a bit too long to connect (or similar), it complains about encryption settings like this. Are you still able to reach the server/port like usual if you do a manual test against that port?
