I am running Nagios Core 4.4.6 on CentOS Stream release 8. Please refer to the below details about nagios and thruk web interface https://www.thruk.org/
#rpm -qa | grep labs-consol
labs-consol-stable-1.4-1.noarch
#rpm -qa | grep thruk
thruk-base-2.44.3-11112.1.x86_64
thruk-2.44.3-11112.1.x86_64
thruk-plugin-reporting-2.44.3-11112.1.x86_64
libthruk-2.44.2-0.x86_64
#rpm -qa | grep epel
epel-release-8-11.el8.noarch
epel-next-release-8-11.el8.noarch
/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 4.4.6
Copyright (c) 2009-present Nagios Core Development Team and Community Contributors
Copyright (c) 1999-2009 Ethan Galstad
Last Modified: 2020-04-28
License: GPL
Website: https://www.nagios.org
Reading configuration data...
Read main config file okay...
Read object config files okay...
Running pre-flight check on configuration data...
Checking objects...
Checked 16 services.
Checked 2 hosts.
Checked 1 host groups.
Checked 0 service groups.
Checked 1 contacts.
Checked 1 contact groups.
Checked 24 commands.
Checked 5 time periods.
Checked 0 host escalations.
Checked 0 service escalations.
Checking for circular paths...
Checked 2 hosts
Checked 0 service dependencies
Checked 0 host dependencies
Checked 5 timeperiods
Checking global event handlers...
Checking obsessive compulsive processor commands...
Checking misc settings...
Total Warnings: 0
Total Errors: 0
Things look okay - No serious problems were detected during the pre-flight check
I am following Thruk - Installation to install Livestatus addon for Nagios which provides real time status data. Is there a way to enable the below entry in /usr/local/nagios/etc/nagios.cfg file. I did search using yum and dnf package manager on CentOS Stream release 8 but unable to locate livestatus.o addon or install it.
broker_module=/opt/local/livestatus/livestatus.o /tmp/live.sock
Any help will be highly appreciable. Please guide/suggest. Thanks in advance.
Best Regards,
Kaushal
