I would like to monitor logfiles of which names rotate every day, so the logfile name is like the current date plus a prefix. For example mylog-20-10-2022.log and so on. Is it possible to dynamically watch these logfiles without a need to add them every day again via manual discovery?
You can use logfile grouping.
In the config file for logwatch “logwatch.cfg” you configure the logfile name and W and C and so on as normal.
/logs/mylogs/mylog-*.log
W warnings
C critical
But instead of putting the full name you put “*” for the part of the logfile that changes.
Then you need to set up logfile grouping
Go to
Setup → Services → Service monitoring rules → Logfile Grouping
Create a rule with something like this
In the section “Logfile Grouping” you add a “pattern group”
Name of the group: My_multiple_logs (this is the name that you will see as a service in checkmk
Include pattern: /logs/mylogs/mylog-*.log (this is the same file name pattern that you set up in “logwatch.cfg”)
